Hey everyone, I wanted to share my experience with the WyzeCam V3 Spotlight issue where it stays on 24/7. I’ve been using Wyze cameras for a while now, and they’ve been a great addition to my smart home setup. However, this particular issue has been quite a puzzle to solve.
First, let me describe the problem. I set up the WyzeCam V3 with the spotlight feature, which is supposed to turn on only when motion is detected. However, shortly after installation, I noticed that the spotlight was on all the time, regardless of motion. This was not only annoying but also a bit concerning in terms of energy consumption.
I started by checking the most obvious solutions. I unplugged the camera, reset it, and updated the firmware. None of these steps worked. The spotlight remained on. I even tried changing the power source, thinking maybe the USB cable was faulty, but that didn’t help either.
Frustrated but determined, I reached out to the Wyze support team. After a few back-and-forth emails, they suggested a factory reset. I followed the instructions, but the problem persisted. It was clear that this wasn’t a software issue but something deeper.
Finally, I stumbled upon a solution in one of the forums. Someone suggested checking the physical connections on the camera. I took it apart (very carefully) and noticed that one of the wires was slightly loose. After reconnecting it properly, the spotlight started behaving as it should—only turning on when motion was detected.
This experience taught me the importance of checking both software and hardware when troubleshooting smart home devices. It also highlighted the value of community support in finding solutions. I’m relieved that the issue is resolved, and I can now enjoy the peace of mind that my WyzeCam V3 provides without the constant glow of the spotlight.
If anyone else is experiencing similar issues, I hope my story helps you troubleshoot and find a solution. Happy smart home tinkering! ![]()
