Hi everyone, I wanted to share my experience with the Xbox API login issue I encountered recently. I was thrilled to integrate my Xbox Live component into my smart home setup, allowing me to trigger automations based on my friends’ online status. However, I faced a recurring problem where the status would change from offline to unknown, accompanied by a 401 error in Home Assistant. This was quite frustrating as the only workaround I found was to relog into xboxapi.com daily.
After some research and experimentation, I discovered a reliable solution. By adjusting the OAuth settings within Home Assistant and ensuring that the API keys were correctly configured, I managed to resolve the issue. It’s essential to verify that your tokens are up-to-date and that there are no firewall restrictions blocking the API requests.
I also found that periodically refreshing the Home Assistant supervisor and ensuring all add-ons are updated can help maintain a stable connection. If you’re experiencing similar issues, I recommend checking your OAuth configuration and verifying your API keys. If the problem persists, reaching out to the Home Assistant community forums can provide additional support and insights.
This experience taught me the importance of thorough configuration and the value of community support in troubleshooting smart home integrations. I hope this guide helps others overcome the same challenge and enhances their smart home experience!
