I’ve been thoroughly enjoying my Xiaomi and Yeelight devices, and I wanted to share some insights regarding their firmware compatibility with openHAB. After experimenting with various firmware versions, I’ve noticed that certain combinations work seamlessly while others require careful handling.
For instance, the Yeelight Ceiling Model (yeelink.light.ceiling1) with firmware 1.5.9_0184 operates perfectly with openHAB versions 2.2 to 2.5, using both the Xiaomi Mi IO Binding and Yeelight Binding. However, manually switching the device on and off remains a necessary step, as brightness adjustments don’t automatically trigger power state changes. This has been a consistent observation across multiple models, including the Yeelight Mono and Stripe versions.
On the other hand, the Xiaomi Air Monitor PM2.5 Model (zhimi.airmonitor.v1) has proven to be highly reliable since openHAB 2.4, consistently providing accurate air quality readings. The Xiaomi Vacuum Model (rockrobo.vacuum.v1) has also been a standout performer, offering stable performance across all tested openHAB versions.
One challenge I encountered was with the Yeelight Ceiling Model (yeelink.light.ceiling5) on firmware 1.5.9_0022. After upgrading to openHAB 2.5, the Yeelight Binding stopped functioning, and I had to revert to the Xiaomi Mi IO Binding. This experience underscored the importance of thoroughly testing firmware upgrades before implementing them across all devices.
To ensure optimal performance, I recommend monitoring firmware updates closely and testing them in a controlled environment before full-scale deployment. Additionally, maintaining clear documentation of firmware versions and their compatibility with specific openHAB releases can save time and prevent potential issues down the line.
If anyone has encountered similar experiences or has tips for managing firmware compatibility, I’d love to hear about them! Let’s continue to collaborate and optimize our smart home setups together.
