I recently set up my Xiaomi motion sensor alongside a Yeelight LED strip, and I wanted to share some tips and tricks I learned along the way. While my initial setup worked, I faced a few challenges that I thought others might relate to or find helpful!
The Setup
I configured my automation to turn on the LED strip when motion is detected and turn it off after a minute of inactivity. Here’s the basic code I used:
yaml
alias: Turn on strip movement
trigger:
platform: state
entity_id: binary_sensor.motion_sensor_xxx
to: ‘on’
action:
service: homeassistant.turn_on
entity_id: light.yeelight_strip_xxx -
alias: Turn off strip movement
trigger:
platform: state
to: ‘off’
for: minutes: 1
action:
service: homeassistant.turn_off
Challenges and Solutions
Timeframe Automation
I wanted the automation to only work during specific times, like at night. After some research, I discovered that usingtime_conditionsin the trigger was the key. This way, the strip only activates after sunset and turns off by sunrise! -
Alexa Integration
While I could manually turn on the strip via Alexa, it would still turn off after the set timeframe. To fix this, I added a condition to check if the strip was manually turned on. If so, the automation respects that state and doesn’t override it! -
Motion Detection Delay
The strip sometimes turned off even when motion was still detected. I realized this was due to the sensor’s sensitivity settings. Adjusting the delay and sensitivity in the Xiaomi app made a huge difference!
Personal Experience
It’s been such a game-changer for my home’s ambiance. The strip adds a warm glow in the evenings, and I love how it automatically adjusts based on my movements. Plus, integrating it with Alexa means I can still manually control it if needed!
If you’re looking to enhance your home’s lighting with motion sensors, I highly recommend experimenting with different automation rules. It’s a fantastic way to save energy while maintaining comfort. Happy automating! ![]()
