I’ve been on a journey to integrate my Xiaomi Roborock S6 vacuum cleaner into my Home Assistant setup, and I’m thrilled to share my success and some tips that might help others!
Initially, I was a bit overwhelmed by the process, but breaking it down step by step made it manageable. I started by ensuring my network settings were correct, as the vacuum needs a stable connection to communicate with Home Assistant. I used the miio tool to discover my device, which was crucial for obtaining the necessary token and device ID.
One challenge I faced was the token generation process. I tried using both the Android app and the miio command-line tool, and while the app was straightforward, the miio method required a bit more troubleshooting. I learned that sometimes the token might not be recognized on the first try, so persistence was key.
Once I had the token and device ID, configuring Home Assistant was smooth. I added the vacuum integration through the configuration YAML, specifying the device ID, token, and name. After a quick restart, my Roborock S6 appeared in the Home Assistant dashboard, ready to be controlled!
I also explored automating my vacuum schedule. Using the built-in automation feature, I set up a routine to start cleaning every evening at 8 PM. It’s been working flawlessly, and I love coming home to a clean floor without lifting a finger.
For anyone looking to integrate their Xiaomi vacuum, here are a few tips:
- Ensure your network is stable to avoid connection issues.
- Double-check your device ID and token for accuracy.
- Don’t hesitate to reach out to the community if you encounter any hurdles; the support here is amazing!
This integration has truly enhanced my smart home experience, and I’m excited to explore more automation possibilities with my Roborock S6. Happy integrating everyone! ![]()
