I recently encountered an issue with my YAMA Automation setup where none of my automations were triggering, despite the motion sensors working correctly. This was quite puzzling as I hadn’t made any changes to my Home Assistant setup around the time the problem started. After some thorough troubleshooting, I discovered that the issue was related to a specific error in the automation traces: ‘Error in describing trigger: Cannot read properties of undefined (reading ‘includes’)’. This error suggested a problem with how the motion sensors were configured within the YAMA blueprint.
To resolve this, I decided to take a systematic approach:
Reviewing Configuration: I carefully examined the blueprint configuration, ensuring that all motion sensors were correctly added and saved. I also checked if the sensors were from different integrations (Hue, ZHA, etc.) to see if that made a difference.
Testing with Different Sensors: I tried replacing the motion sensors with others from my setup to isolate the problem. Interestingly, the issue persisted regardless of the sensor type, which indicated that the problem wasn’t with the sensors themselves but with the automation setup.
Seeking Community Help: I reached out to the Home Assistant community forums, where I found that others had encountered similar issues. Through their insights, I learned that updating the blueprint or checking for any undefined variables in the trigger conditions might be the solution.
Final Fix: After some trial and error, I realized that the issue was due to a missing or undefined entity in the automation’s trigger conditions. By ensuring all referenced entities were correctly defined and available, the automations started working again.
This experience taught me the importance of thorough configuration checks and the value of community support in troubleshooting complex issues. It also highlighted the need for clear error messages in automation setups to aid in quicker resolutions.
