I recently came across the Yet Another Motion Automation (YAMA) blueprint and decided to give it a try. It’s been a fantastic addition to my smart home setup! ![]()
My Setup Journey
I’ve always wanted a seamless way to control my lights based on motion, especially in areas like the hallway and kitchen. After spending some time configuring the blueprint, I was impressed by its versatility. Here’s what I did:
- Trigger on Motion: I set it up to trigger when my hallway motion sensor detects movement. It automatically turns on the lights and adjusts their brightness based on the time of day.
- Scenes for Different Times: I configured four scenes—morning, day, evening, and night—each with its own lighting preset. This ensures the lights adapt to the natural light available throughout the day.
- Sun Elevation Check: I enabled the sun elevation feature to avoid turning on lights during the day when natural light is sufficient.
- Automation Blocker: I added an automation blocker using an input boolean to pause the automation when needed (like during movie nights).
The Learning Curve
At first, I was a bit overwhelmed by the number of settings, but the documentation and community support made it manageable. I recommend starting with basic settings and gradually adding more features as you get comfortable.
A Little Glitch and How I Fixed It
One thing I struggled with initially was getting the scenes to switch correctly. After some troubleshooting, I realized I needed to adjust the time frames for each scene to match my daily routine. Once that was sorted, everything worked like clockwork!
Why I Love YAMA
- Customization: It’s highly customizable, allowing me to tailor it to my specific needs.
- User-Friendly: Despite being a complex automation, it’s surprisingly easy to set up and modify.
- Reliable: It consistently performs well, even during peak usage times.
Tips for New Users
- Start Simple: Begin with basic motion detection and light control before adding advanced features.
- Experiment with Scenes: Play around with different lighting presets to find what works best for your space.
- Leverage the Automation Blocker: Use it to pause the automation during specific activities to avoid disruptions.
YAMA has completely transformed how I interact with my smart home. It’s not just about convenience—it’s about creating a comfortable and personalized living environment. If you’re looking for a robust motion automation solution, I highly recommend giving YAMA a try! ![]()
Happy automating! ![]()
