Z-Wave Metering Plug Not Sending Scheduled Reports
I’ve been using a Z-Wave metering plug in my setup, and everything was working perfectly until recently. The plug is configured to send scheduled reports every 60 seconds, but despite the settings, I’m not receiving these reports. Polling works fine, and I can manually retrieve data, but the unsolicited reports are missing. This is a bit frustrating as I was hoping to reduce the load on my system by relying on scheduled updates instead of constant polling. I’ve checked the device associations and configurations multiple times, and everything seems to be set up correctly. The device is part of the lifeline group, which should handle the data transmission. I’m wondering if there’s a specific configuration or setting I might have missed that’s causing this issue. Has anyone else experienced similar problems with Z-Wave devices not sending scheduled reports? Any insights or suggestions would be greatly appreciated!
