Z-Wave Module Replacement & Temperature Sensor Calculation
I recently faced an interesting challenge with my Conexis locks using Z-Wave modules. After upgrading to the Yale Home app, I was concerned about losing HomeKit compatibility. However, I found a clever workaround by swapping the Z-Wave module with the Yale Home module for firmware updates and then reverting back. This solution allows me to maintain Z-Wave integration while benefiting from the Yale Home app’s features. It’s a bit of a hassle, but it keeps everything running smoothly!
On another note, I’ve been experimenting with calculating the water level in my underground tank. Knowing the tank’s height (72 inches) and capacity (4,200 liters), I wanted to determine the remaining water volume. After some research, I discovered that the formula involves dividing the water height by the tank’s total height and multiplying by the total capacity. While I haven’t fully implemented this in Home Assistant yet, it’s a promising approach for monitoring water levels accurately.
Lastly, I stumbled upon a user discussing issues with MQTT configuration for Aqara double switches. They were struggling with state updates after removing the value_template. I recall that newer MQTT versions handle state topics differently, so ensuring the correct state and command topics are set is crucial. It’s a reminder of how important it is to stay updated with the latest documentation and community discussions to troubleshoot effectively.
Overall, these experiences highlight the creativity and resourcefulness needed in the world of smart home automation. Whether it’s module swapping, formula calculations, or MQTT troubleshooting, the journey is both challenging and rewarding!
