ZemiSmart Smart Matter Hub Review: A Comprehensive Look
After spending several weeks testing the ZemiSmart Smart Matter Hub M1, I’m excited to share my experience with this innovative device. Designed for those looking to integrate Matter, Thread, and Zigbee devices into their smart home ecosystem, the M1 has proven to be a reliable and versatile addition to my setup. Here’s a breakdown of my experience and some tips for getting the most out of this hub.
Out of the Box Experience
The packaging is clean and minimalist, with the Matter logo prominently displayed—a clear indication of its purpose. Inside, you’ll find the hub itself, a USB-C to USB-A cable, a manual, and a SIM pin for resetting the device. The hub’s design is sleek, with a matte finish and subtle branding. The Matter QR code on the underside is a nice touch, making initial setup straightforward.
Setup and Initial Impressions
Setting up the M1 was a breeze. I used the Matter QR code to add it to my Apple Home ecosystem, and it paired seamlessly with my existing Zigbee devices. However, I noticed that adding sub-devices required the Tuya app initially. This was a bit confusing at first, but once I got the hang of it, the process became smooth. The hub’s ability to act as both a Matter controller and a Thread Border Router is impressive, especially for those looking to future-proof their smart home.
Performance and Compatibility
I tested the M1 with a variety of devices, including sensors, smart plugs, and even a Matter-over-Thread bulb. The hub handled all these devices effortlessly, maintaining stable connectivity even through walls. One feature I particularly appreciated was its improved Zigbee signal strength compared to previous models, which made pairing devices a cinch.
For users of platforms like Google Nest or Amazon Alexa, the M1’s versatility is a major plus. While it’s optimized for Tuya devices, its Matter compliance ensures compatibility with a wide range of ecosystems.
Tips for Getting Started
  1. Use the Tuya App Initially: While it’s possible to add the hub directly to your Matter platform, using the Tuya app for initial setup simplifies adding sub-devices.
  2. Delete the Tuya App Once Configured: Once all your devices are paired, you can safely remove the Tuya app, leaving your setup clean and localized.
  3. Check for Firmware Updates: ZemiSmart has been proactive in addressing bugs, so keeping your hub updated is essential for optimal performance.
Conclusion
The ZemiSmart Smart Matter Hub M1 is a solid choice for anyone looking to embrace the latest in smart home technology. While it may not be perfect for every use case, especially for those deeply invested in Apple Home, its support for Matter and Thread makes it a forward-thinking device. If you’re ready to explore the next generation of smart home connectivity, the M1 is definitely worth considering.
Happy automating! :rocket:
