Hey everyone, I’m reaching out to share my recent experience with the Zen32 smart bulb in ceiling fan mode. It’s been a bit of a rollercoaster, but I wanted to document my journey in case it helps others who might be facing similar issues. Here’s what happened:
I recently installed a Zen32 smart bulb in my ceiling fan setup, using Bond to control both the fan speed and light. Everything was working smoothly until yesterday when the fan suddenly stopped responding. The bulb was still powered, and I could see the button presses in Hubitat’s logs, but the fan itself wouldn’t budge. The rule fired, and Bond reflected the status change, but there was no response from the fan. This was puzzling!
I started by checking the basics: power supply, connections, and the Zen32’s status. The bulb itself seemed fine, but I wondered if the Zen32 had entered some sort of funky state where it wasn’t passing power to the fan. I tried resetting the switch by pulling the air gap, but there wasn’t one visible on the Zen32. My next thought was to trip the breaker, but I wanted to explore other troubleshooting steps first before taking it out and replacing it with my spare.
Here’s what I tried:
- Double-checked all wiring connections to ensure nothing was loose.
- Verified that the Zen32 was receiving power and functioning correctly as a bulb.
- Reviewed the Bond app for any hidden settings or firmware updates.
- Tested the fan manually by disconnecting it from the Zen32 to rule out a hardware issue with the fan itself.
After several hours of troubleshooting, I decided to reset the Zen32 by removing it from the circuit and letting it sit for a while. When I reconnected it, the fan sprang back to life! It turned out to be a temporary glitch in the Zen32’s communication with the fan. I’m relieved it wasn’t a hardware failure, but this experience has made me more cautious about relying solely on smart bulbs for critical functions like fan control.
Takeaways:
- Always test your setup thoroughly after installation.
- Keep spare components on hand for quick replacements.
- Don’t hesitate to reach out to the community for advice—sometimes a fresh pair of eyes can spot the issue faster!
If anyone has encountered similar issues or has additional troubleshooting tips, I’d love to hear from you! Happy smart home tinkering!
