Zigbee 3.0 Power Strip Review: A Cost-Effective Smart Solution
I recently came across this Zigbee 3.0 power strip from AliExpress, and I must say, I was pleasantly surprised by its performance. Initially, I was skeptical because the packaging and instructions mentioned ‘WiFi Smart Power Strip,’ which made me think it might be a hassle to set up. However, upon receiving it, I discovered it’s fully compatible with Zigbee, which was a breath of fresh air for my smart home setup.
Product Features
The power strip boasts several features that make it a great addition to any smart home:
  • 4 USB Ports: These are always on, providing convenient charging solutions for devices like phones and tablets.
  • 4 Spaced Outlets: Each outlet is individually controlled, allowing for precise management of connected devices.
  • Zigbee Compatibility: It seamlessly integrates with my existing Zigbee ecosystem, eliminating the need for additional hubs or complicated configurations.
Pros and Cons
Pros:- Affordable: At just $28, it’s a budget-friendly option without compromising on functionality.
  • Reliable Performance: The power strip has been running smoothly in my setup, with no connectivity issues despite being placed in a corner of my house.
  • Versatile: It’s perfect for controlling devices like lamps, fans, or small appliances, adding a layer of automation to daily routines.
Cons:- Loud Relays: The relays can be quite noisy when switching on or off, which might be a minor inconvenience in quiet environments.
Integration Experience
Setting up the power strip was straightforward. I simply paired it with my Hubitat hub, and it recognized the device without any issues. I’ve used it to automate my living room lights, ensuring they turn on when I enter the room and off when I leave. The ability to control each outlet individually has been particularly useful, as I can now manage my entertainment system without manually switching devices on and off.
Conclusion
Overall, this Zigbee 3.0 power strip has exceeded my expectations. It’s a reliable, cost-effective solution that enhances the functionality of my smart home. If you’re looking to add more automation without breaking the bank, I highly recommend giving this product a try. It’s a great way to expand your smart home capabilities without the hassle of complex setups.
