Hello everyone, I wanted to share my experience with the Zigbee2mqtt setup on Home Assistant. I’ve been using the Texas Instruments CC2531 adapter on my Home Assistant Blue, and it’s been working perfectly for the most part. However, I’ve encountered a puzzling issue where the adapter suddenly stops working after some time. Restarting the Zigbee2mqtt add-on or even rebooting the entire server doesn’t seem to help. The only solution I’ve found so far is to physically unplug and replug the adapter into the USB port.\I’m curious if anyone else has faced this problem or has any insights into why this might be happening. Could it be related to power management settings, firmware issues, or perhaps something with the USB port itself? Any advice or troubleshooting steps would be greatly appreciated!\Thanks in advance for your help! ![]()
