Hi everyone, I wanted to share my recent experience with setting up Zigbee automation in my smart home. While it was a bit challenging at first, I managed to get everything working smoothly, and I’d love to share my journey and some tips that might help others facing similar issues.First, I encountered a problem with Zigbee2MQTT not starting properly on my new Home Assistant setup. The interface kept showing ‘Loading, please wait,’ which was frustrating. After some research and reaching out to the community, I discovered that installing the edge version resolved the issue. It’s always a good idea to check forums and community discussions if you run into similar problems.Once Zigbee2MQTT was up and running, I focused on creating an automation to control my curtains based on window status and sunset times. Initially, the automation didn’t trigger as expected when the window was closed. After reviewing my configuration, I realized I needed to add additional conditions to ensure the curtain only closes when the window is shut and the sun is setting. This experience taught me the importance of thorough testing and the value of community support in troubleshooting.I also wanted to share a helpful tip for anyone working with Zigbee devices: always ensure your firmware is up to date. Outdated firmware can cause connectivity issues and hinder automation performance. Additionally, using the Home Assistant developer tools, like the State Trigger card, can provide deeper insights into how your automations are functioning.Reflecting on this project, I’m proud of how far I’ve come with my smart home setup. It’s been a great learning experience, and I’m excited to continue expanding my system. If anyone has questions or needs advice on similar projects, feel free to reach out—I’m happy to help!
