Zigbee Device Migration Success Story
Hey everyone, I recently had the opportunity to dive into a fascinating project involving the migration of Zigbee devices during a fresh installation of Home Assistant. It’s been quite the journey, and I’d love to share my experience with you all. **If you’ve ever wondered how to transfer Zigbee devices without relearning them, this post is for you!**I recently decided to completely reinstall Home Assistant on my Proxmox server. While this was a fresh start in many ways, I wanted to retain all my Zigbee devices from my previous setup. The challenge? Ensuring these devices would work seamlessly without needing to be relearned. The Zigbee coordinator remained the same, but the question was: how could I transfer these devices to the new installation?After some research and trial and error, I found a solution that worked perfectly. It turns out that the Zigbee database can be backed up and restored, allowing the new installation to recognize all previously learned devices. Here’s a quick rundown of what I did:1. Backup the Zigbee Database: Before reinstalling, I made sure to back up the Zigbee database from my old installation. This database contains all the necessary information about your devices.2. Restore the Database: Once the new installation was up and running, I restored the Zigbee database. This step was crucial as it allowed the new system to recognize all my existing devices.3. Re-add Devices Manually: While the database restoration handled the bulk of the work, I still needed to manually re-add each device in the Home Assistant interface. This process was straightforward and only required a few clicks per device.4. Test Each Device: After restoring and re-adding, I tested each device to ensure they were functioning as expected. It’s always good to double-check!I must admit, there were a few moments of uncertainty, especially when I wasn’t entirely sure how the database restoration would work. However, the process turned out to be much smoother than I anticipated. The key takeaway here is that while migrating Zigbee devices isn’t the most intuitive process, it’s definitely doable with the right approach.If anyone else has tackled a similar project or has tips to share, I’d love to hear about your experiences! Let’s continue to support each other in this amazing community. :handshake:
