Hey there! I’m trying to set up my Zigbee motion sensor to turn off the light after 5 minutes of being triggered, but I’m hitting a wall. Let me walk you through what I’ve done so far and where I’m stuck.
I have a Sonoff Zigbee motion sensor that’s successfully automating my light to turn on when motion is detected. The sensor works perfectly for turning the light on, but now I want to create another automation to turn it off automatically after 5 minutes. I’ve tried a few different approaches, but nothing seems to be working.
Here’s what I’ve tried:
- I’ve set up a timer in the automation editor, but it doesn’t seem to trigger the light to turn off.
- I’ve checked the sensor settings to make sure it’s correctly configured.
- I’ve reviewed the logs, but there’s no clear error message indicating where the issue is.
If anyone has successfully set up a similar automation, I’d really appreciate your advice or any tips on how to troubleshoot this. Maybe there’s a setting I’m missing or a different approach I should take.
Thanks in advance for your help! Let’s see if we can crack this together. ![]()
