Hello everyone, I wanted to share my recent experience with a Zigbee network delay issue and how I managed to resolve it. After performing some maintenance on my home server, which hosts my Zigbee network via deCONZ, I encountered significant delays in communication with my devices. The logs were filled with repeated attempts to send requests, which were either delayed or resulted in errors. This was quite frustrating, especially since the setup had been working perfectly before the maintenance.
After some research and troubleshooting, I realized that the issue might be related to the network configuration or interference. I decided to switch the Zigbee channel, which is a common solution for connectivity issues. However, this didn’t resolve the problem entirely. I then considered the possibility of hardware interference and repositioned the ConBee II stick to minimize any potential disruptions.
The breakthrough came when I reviewed the logs more carefully and noticed patterns in the delays. It appeared that certain devices were causing prolonged delays due to their high-frequency communication. I decided to isolate these devices temporarily and observed a significant improvement in the overall network performance. This experiment helped me identify the problematic devices, which I then updated to ensure they were running the latest firmware.
Another aspect I explored was optimizing my automation scripts. I had a complex script that relied heavily on multiple devices communicating simultaneously. By breaking down the script into smaller, more manageable tasks and implementing delays between each task, I was able to reduce the load on the network and improve responsiveness.
I also found that using the deCONZ web interface to monitor the network in real-time was incredibly helpful. It allowed me to pinpoint exactly where the delays were occurring and adjust my setup accordingly. Additionally, I discovered that resetting the Zigbee network and re-commissioning all devices, while time-consuming, was a reliable method to eliminate persistent issues.
Through this process, I learned the importance of systematic troubleshooting and the value of community resources. I’m grateful for the wealth of information and support available in forums like this, which helped me navigate what initially seemed like an insurmountable problem. If anyone else is experiencing similar issues, I highly recommend checking the network configuration, updating firmware, and monitoring the network traffic closely.
