Zigbee Stability Issues and Troubleshooting
I’ve been diving into the world of Zigbee lately, and while it’s been a fantastic journey, I’ve hit a bit of a snag. After moving my Home Assistant setup to a different VLAN to get my Google Home integration working, I noticed something odd—my Zigbee network started crashing every few minutes. :stop_sign::sparkles:
Let me walk you through what I’ve experienced and what I’ve tried so far:
The Problem
After the move, I started seeing these error logs in my Zigbee2MQTT setup:
[2025-07-14 19:25:30] error: zh:ember:uart:ash: Received frame with CRC error
[2025-07-14 19:26:04] error: zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS
And it just keeps happening, which is pretty frustrating because I’ve got 32 Zigbee devices that rely on this setup! :stop_sign:
What I’ve Tried
  1. USB Port Changes: I moved the Zigbee stick to different USB ports, used a powered USB hub, and even tried a direct connection. No luck! :desktop_computer::electric_plug:
  2. Firmware Updates: I updated the firmware on the stick, but it didn’t make a difference. :hammer_and_wrench::arrows_counterclockwise:
  3. Power Cycles: I restarted everything—my router, the Zigbee stick, and even the host machine. Still nothing. :arrows_counterclockwise:
  4. Log Analysis: I’ve poured over the logs, and it seems like communication timeouts and CRC errors are the main culprits. :clipboard::mag:
Thoughts and Next Steps
  • Interference Check: I’m wondering if there’s some wireless interference now that I’m on a different network. Maybe moving the Zigbee stick closer to the router or away from other devices could help? :signal_strength:
  • Reset Network: I’m considering resetting the Zigbee network entirely. It’s a bit scary because I’d have to re-pair all my devices, but maybe that’s the only way to get a fresh start. :stop_sign::arrows_counterclockwise:
  • Alternative Firmware: I’ve heard about different firmware versions for Zigbee sticks. Maybe trying a different one could stabilize things? :hammer_and_wrench:
Community Help
If anyone has dealt with similar issues or has troubleshooting tips, I’d be super grateful! I’m really hoping to get this sorted without having to buy new hardware. Fingers crossed! :crossed_fingers:
Let’s keep the conversation going and see if we can crack this together! :computer::sparkles:
