Hi everyone, I wanted to share my recent experience setting up Zigbee2mqtt on my Raspberry Pi. It’s been a bit of a learning curve, but I’m thrilled with how everything came together! ![]()
I started by installing the ConBee II stick and followed the initial setup guide. Everything worked smoothly with Deconz, and I was able to add a few Aqara sensors without any issues. However, when I decided to switch to Zigbee2mqtt for its MQTT integration, I ran into some hurdles.
The main problem was a ‘Broken pipe’ error when trying to start the service. After some research, I realized that running both Deconz and Zigbee2mqtt simultaneously was causing conflicts. Uninstalling Deconz and reinstalling Zigbee2mqtt from scratch helped, but I still faced issues with the USB access. I had to ensure that no other services were using the USB port before starting Zigbee2mqtt.
Another thing I discovered was the importance of proper configuration settings. I adjusted the config.yaml file to specify my MQTT broker details and USB port correctly. I also found that setting the log_level to ‘warn’ made the logs easier to read and troubleshoot.
For anyone else going through this, I recommend checking the official troubleshooting guide and verifying that all dependencies are correctly installed. Also, ensuring that your Raspberry Pi has the latest updates and sufficient resources helps prevent unexpected issues.
Now that everything is up and running, I’m excited to expand my Zigbee network with more devices. It’s amazing how seamless the integration with MQTT is, and I can’t wait to explore more automation possibilities! ![]()
If anyone has tips or tricks for optimizing Zigbee2mqtt performance, I’d love to hear them! Happy coding and happy automating! ![]()
