Zoned HVAC - Aqara W200s with FP300 Presence Sensors
I have a Zoned HVAC System and I’m using 4 Aqara W200 Thermostats to control the 4 zones. Everything is integrated in Apple Home so I’m not using any of the Aqara native capabilities.
I have the W200s set up to use Apple’s Adaptive Temperature. When someone is present in a zone, then I want to heat or cool that zone to maintain a narrow range of comfortable temperatures. If that zone is not occupied, then its ok to relax the heating and cooling limits to save some money.
For simple zones, the W200 has a built in occupancy detector which I use to trigger the Thermostat to use the “At Home” heating and cooling settings. When no one is present in that zone, after some delay, the W200 reverts to the “Away” heating and cooling settings defined in Apple Adaptive Temperature. Rinse and repeat.
However, I have some zones that include multiple rooms. In those zones I want to trigger the use of the “At Home” settings if any of the rooms in that zone are occupied. The problem is that the thermostat’s occupancy detector by definition is located in one of those rooms. If no one is present in that room, that zone will eventually transition to the "Away"setting even though the other rooms in the zone may be occupied. To be honest, this would be unsuitable.
To Attempt to remedy this, I integrated FP300 Presence Sensors placed in the “other” rooms of my large multi-room zones. I used the Zigbee interface to integrate each the FP300s with a selected W200.
From experimentation, it appears that a multi-room zone will use the “At Home” settings when 1) either the W200’s internal occupancy detector is triggered, or 2) an “attached” FP300’s occupancy detector is triggered. By “attached” I mean an FP300 that uses that particular W200 as its Zigbee Hub.
I haven’t been able to find any description of this detail anywhere. I wanted to understand whether this behavior is how these things are designed or whether it is in some sense accidental.
It seems to me that having a large multi-room HVAC zone where you want to detect occupancy in any of the rooms in that zone is a pretty standard use case. I don’t think I’m trying to do something that is particularly unusual here.
Has anyone else tried this kind of setup?
The closest official documentation I found is Aqara’s Follow Presence announcement. It describes choosing temperature and humidity data from occupied rooms, with Average, Maximum or Minimum options when several rooms are occupied. That documents presence-aware climate control in Aqara, but it does not explicitly say that every FP300 paired to a W200 is automatically OR-combined with its internal occupancy sensor to drive Apple’s Adaptive Temperature state. I have not tested this W200 and Apple Home combination myself.
To isolate the behaviour, I would keep the phone’s Home/Away state unchanged, leave the thermostat’s room empty, occupy only the FP300 room, then let both rooms become empty for the normal delay. I would also check that a sensor in another HVAC zone cannot keep this W200 at Home. Could Aqara confirm whether the occupancy grouping follows the Zigbee parent hub or an explicit sensor association? That distinction would establish whether this is a supported per-zone behaviour rather than simply a side effect of another presence rule.
I did run exactly the experiment that you described but with mixed results.
I have a Zone with a W200 Thermostat in our Guest Room and an FP300 located in my Office. Both rooms are on the second floor so my requirement is that occupancy in either room should trigger to Thermostat to use the “At Home” settings in Apple’s Adaptive Temperature. The FP300 in my office is integrated using Zigbee via the W200 in the Guest Room. That Thermostat’s settings in Apple Home identify the Office FP300 as an “accessory”.
This morning everything had settled overnight with no occupancy detected in either room. The Thermostat was using the relaxed Away settings. I came upstairs and went into my Office and immediately that W200 in the Guest Room transitioned into “At Home” mode exactly as I want. Good news, this seems aligned with my requirement.
I have another more complicated zone downstairs. The W200 Thermostat is located in the Dining Room and I have two FP300s located in the Kitchen and in the Living Room. The requirement is that occupancy in any of these rooms should trigger the Dining Room thermostat to transition to “At Home” mode. Both FP300s are integrated using Zigbee via the W200 in the Dining Room. That Thermostat’s setting in Apple Home identify the Dining Room W200 as having two accessories. This all looks as expected.
This morning everything had settled overnight with no occupancy reported in any of the relevant 3 rooms. The Dining Room Thermostat was using the relaxed Away settings. I went into the Living Room and triggered the occupancy sensor there (I checked in Apple Home to verify this) but the Dining Room W200 did not transition; it remained in the “Away” mode. I went into the kitchen and immediately the Dining Room W200 transitioned into “At Home” mode. So unfortunately, this zone is not quite doing what I want.
In summary, the Guest Room/Office zone seems to be doing what I want. However, the larger three room zone isn’t behaving as I would like.
Thinking more broadly - I think its quite common to have a large zone with 3 or 4 rooms and a single Thermostat in one of those rooms. In a multi-story home with bedrooms on the second floor, I would expect this arrangement to be quite typical. The whole Adaptive Temperature concept breaks down if you can only trigger use of the “At Home” settings by occupying one of the bedrooms.
Apple Home permits you to define the trigger for transition to “At Home” but you can only choose “Anyone is at home (in any room)” or you can identify a single room as a trigger. This isn’t adequate for a set of typically encountered situations. It should be possible to trigger this transition using occupancy in multiple rooms "Or"ed together (e.g., Room A or Room B or Room C).
It looks like the Aqara behavior goes part of the way to addressing but doesnt quite cover all the cases of interest. My other concern is that this behavior may be accidental and not by design. Accidental design is subject to change at any point in the future. If this is by design, then it seems to have some holes in its logic right now.
I want to run these same experiments a few more times and look for consistent behavior. We’ll see.
For the next round, I’d make each downstairs trial start from the same fully vacant, Away state. Test the Kitchen alone and the Living Room alone in alternating order, without walking through the other sensor’s area. For each trial, record the FP300 occupancy shown in Apple Home, the exact room selected for Adaptive Temperature’s At Home trigger, the W200’s mode before and after, and the delay. That would help distinguish a repeatable room or accessory mapping problem from one successful transition carrying over into the next test.
I would also add an all-vacant control after each occupied trial. The occupancy aggregation you need has to work in both directions: any occupied room should hold that zone at Home, and the zone should become Away only after every relevant room is vacant for the intended delay. If the Living Room consistently reports occupancy while the W200 stays Away, that paired record, plus the devices’ firmware versions, would give Aqara a much more specific case to investigate. I would not treat listing both accessories as proof that both are included in Adaptive Temperature’s trigger.
To my surprise this remote sensor behavior I had previously observed stopped working entirely for all thermostats on Sunday.
I have to walk into the detection zone in front of each thermostat now to get it to transition to the “At Home” settings.
At the moment I can see that the Apple Home has detected occupancy in my office and the Guest Room thermostat continues to use its “Away” Adaptive Temperature settings.
Similarly, Apple Home reports occupancy in the Kitchen but the Dining Room thermostat continues to use its “Away” Adaptive Temperature settings.
I don’t know what changed. I had an interval Sunday morning when Apple Home running on my desktop could not get updates from any of the Thermostats for an extended interval. At the same time Home running on my Phone seemed to be fine. But I am hard pressed to imagine how this might have affected things.
One thing I did Sunday morning was to turn on Notifications for each of the FP300s. Later in the day I turned these off again.
I now suspect that the behavior I had previously observed was entirely accidental.
Based on the current behavior I’m seeing, it looks like Adaptive Temperature isn’t terribly useful without more flexible rules for the triggers that force transition between the "At Home’ and “Away” settings. To be really useful for multi-room zones, the Adaptive Temperature triggers need to include the capability to select multiple occupancy sensors such that if any of those sensors are triggered, the thermostat transitions to the “At Home” settings.
This new result narrows the failure path: according to your observations, FP300 occupancy still reaches Apple Home and the W200’s own detector still changes the mode, but the remote occupancy no longer does. During the next occurrence, I’d compare the phone and desktop at the same time and note whether the thermostat itself changes its target. That would help distinguish a stale client view from an actual missing transition. The notification toggle belongs in the timeline, but timing alone does not establish that it caused the change.
Before resetting or re-pairing anything, I’d record the active Apple home hub and its software version alongside the W200 firmware and incident time. Apple’s documentation shows the active hub under Home Settings > Home Hubs & Bridges. A shared hub or software change is something to investigate, not a diagnosis or proof that FP300 aggregation was supported. Those details would make the change across all zones more useful to support than another isolated sensor trial.
In the end I gave up on this since:
Apple’s adaptive temperature does not allow adaptive temperature transitions to be triggered by any member of a set of presence detectors.
An alternative would be to write automations that consider the state of the relevant presence sensors. However, Apple’s Adaptive Temperature function is a black box and you cannot write automations to trigger transitions between adaptive temperature parameter sets based on the state of individual presence detectors.
In the end, I set up my large multi-room zones to transition based on presence in the home:
68F to 78F when anyone is home
64F to 78F when no one is at home
60F to 82F when no one has been at home for more than 24 hours
These zones also have an additional set of ranges defined for nightime (per the schedule I defined): 64F to 78F
I then set up smaller single room zones to transition based on presence in the room:
68F to 78F when anyone is in the room
64F to 78F when no one is in the room
These zones do not allow a nightime range to be defined.
Although this isnt the solution I was originally aiming for, I’ve been monitoring its behavior and it seems to be doing fairly well so far.
