Recently, I decided to dive into setting up my own NVR using Zoneminder, and I wanted to share my experience in case it helps anyone else who might be considering the same journey. This guide is based on my setup using Docker, which I found to be a smooth and efficient way to get everything up and running.
First off, I wanted to mention that I stumbled upon dlandon’s Docker repository for Zoneminder, and it’s been an absolute lifesaver. The preconfigured settings and the inclusion of face/object detection via YOLO and Tiny YOLO made it even more appealing for me, especially since I was transitioning from Shinobi.
My setup is as follows: I’m using Docker on a Synology NAS with a reverse proxy set up using NGINX. I have a mix of Wi-Fi and PoE IP cameras, and I wanted to make sure everything was neatly organized under a subdomain structure. For example, I have camera.domain.com for accessing the portal and zmninja.domain.com for handling websockets. This setup not only keeps things tidy but also makes it easier to manage incoming traffic.
One of the first steps I took was to run the id command to retrieve my GUID and PUID. This was essential for setting up the Docker container correctly. I then proceeded with the Docker command, making sure to adjust the time zone to match my location. I also made sure to enable the necessary hooks and face detection features by setting the appropriate environment variables.
After the initial setup, configuring Zoneminder itself was a breeze. I added my monitors, customized the alarm settings, and set up zones. One thing I found particularly useful was enabling the ENABLE_AUTH_HASH option, which added an extra layer of security. I also took the time to create a new admin user with appropriate access rights, ensuring that everything was secure from the get-go.
When it came to testing the setup, I utilized ZMninja on both my PC and iOS devices. It’s worth noting that the paid iOS version is required for FCM alerts, which I found to be a minor inconvenience but manageable overall. I also made sure to update the zm_user and zm_pass credentials in the secrets.ini file, ensuring that everything was in sync with my new admin account.
One challenge I encountered was setting up the reverse proxy on my Synology NAS. It required a bit of tweaking to get the SSL certificates working correctly, but once I got past that, everything fell into place. I also had to make sure that the necessary ports were forwarded correctly on my router, which was a crucial step in ensuring that everything was accessible externally.
For anyone looking to integrate MQTT into their setup, I found that it was straightforward to configure. I made sure to enable SSL in the MQTT settings and adjusted the IP addresses and credentials accordingly. This allowed me to seamlessly integrate my Zoneminder setup with other MQTT-enabled devices in my smart home ecosystem.
Throughout the entire process, I kept meticulous notes and was patient, especially during the initial build phase of the Docker container. It’s important to remember that this is a complex setup, and taking the time to troubleshoot and verify each step is well worth the effort in the long run.
In conclusion, setting up Zoneminder via Docker has been an incredibly rewarding experience. It’s powerful, flexible, and has given me the ability to monitor and secure my home in ways I never thought possible. If you’re considering diving into the world of NVRs, I highly recommend giving Zoneminder a try. It’s a bit of a learning curve, but the payoff is well worth it. Happy configuring!
