I recently upgraded to the Zooz ZEN30 double switch and installed the new 2.1.8 driver. While the dimmer functionality works perfectly, I noticed that controlling the relay part of the switch was initially a bit tricky. After some research and experimentation, I found that reinstalling the switch using the new driver resolved the issue. Here are a few tips for anyone else going through this process:
- Backup Your Settings: Before making any changes, ensure you have a backup of your current setup. This can save a lot of time if something goes wrong.
- Follow Configuration Commands: The configure command was essential for setting up the switch correctly. It helped create the necessary child devices without any issues.
- Test Thoroughly: After installation, test both the dimmer and relay functionalities extensively. This helps in identifying any potential issues early on.
- Community Support: If you run into any problems, don’t hesitate to reach out to the community. Forums like this are invaluable for troubleshooting and sharing experiences.
Overall, the Zooz ZEN30 is a fantastic addition to my smart home setup, and I’m grateful for the support from the community in making the transition smooth. Happy smart home tinkering everyone!
