Hi everyone,
I’m new to the world of Home Automation and I’m really excited to be part of this community. I’ve recently set up my first Z-Wave device, the Zooz ZSE29 Outdoor Motion Sensor, and I wanted to share my experience and some tips that might help others who are just starting out.
I installed the sensor using an Aeotec USB controller and integrated it into Home Assistant (HA) running on a Docker container hosted on Ubuntu VM. The setup went smoothly, and I was able to pair the sensor without any issues. However, when I tried to create an automation to turn on the outside lights when motion is detected, nothing happened, even though the sensor was blinking red to indicate it was triggered.
After spending hours troubleshooting, I realized that the sensor was in a ‘sleeping’ state, which is normal for battery-powered devices to conserve energy. To ensure the sensor is active, I had to adjust the wake-up interval in HA’s Z-Wave management settings. Once I did that, the sensor became responsive, and my automation started working as expected!
Here’s a quick tip for anyone experiencing similar issues: Always check the sensor’s status in HA and ensure it’s not in a low-power mode. If it is, adjust the wake-up interval to a shorter duration to keep it active.
I also found that manually triggering the automation in HA helped me identify if the issue was with the sensor or the automation itself. It’s a great way to test and debug your setups.
Thanks to the community for all the helpful resources and support! If anyone has questions or needs assistance with their Zooz ZSE29 sensor, feel free to reach out. I’m happy to help and learn together!
Cheers,
