Hello everyone! I wanted to share my experience with the Zooz ZSE40 v2.0 4-in-1 sensor, specifically focusing on its humidity monitoring capabilities. I’ve been using these sensors in my bathrooms to trigger the exhaust fan during high humidity periods, and overall, I’m quite satisfied with their performance. However, I did run into a minor issue that I thought might be worth discussing with the community.
Initially, I noticed that the sensor wasn’t reporting humidity changes as frequently as I expected. Regardless of the RH change trigger settings I selected, there was a noticeable delay—often more than five minutes between reports. This was a bit concerning because I wanted the exhaust fan to activate promptly when humidity levels rose. After some research and experimentation, I realized that this might be a limitation of the device rather than an error in my setup. However, I also discovered that adjusting the sensor’s placement and ensuring it has a clear view of the bathroom environment can help improve its responsiveness.
One thing I’ve really appreciated about these sensors is their reliability in other areas. They consistently detect motion, door status, and temperature changes, which adds a lot of value to my smart home setup. The fact that they’re battery-powered and don’t require constant wiring is another major plus for me.
For anyone else looking to use these sensors for humidity monitoring, I’d recommend experimenting with different placement strategies and keeping an eye on the sensor’s settings to optimize its performance. If you’re experiencing similar delays, feel free to share your experiences or tips in the comments below—I’d love to hear how others have tackled this!
Overall, I’m happy with the Zooz ZSE40 v2.0 sensors and would definitely recommend them for those looking for a versatile, multi-functional smart sensor solution. It’s a great way to enhance home comfort and efficiency!
Best regards,
