Hi everyone,
I’m using the Aqara M100 hub with several door sensors, connected to both Home Assistant and HomeKit.
As you probably know, HomeKit automations for arming/disarming the “alarm system” (the M100 hub) when arriving or leaving home require manual user confirmation.
To bypass this, I set up a Geofencing automation directly in the Aqara app — when I leave or arrive home, it changes the hub’s alarm mode, which then syncs to HomeKit. I also added a notification as a test indicator.
Here’s what happens:
- When I leave home, the automation works perfectly — the system arms as expected.
- When I arrive home, I receive the notification saying the system should be disarmed and confirming my arrival, but the alarm mode doesn’t actually change in HomeKit.
- I’ve tried setting it to both Off and Home mode, but it stays stuck in Away mode.
Has anyone else experienced this?
Is this a known issue or is there a workaround?
Thanks in advance for any insights!
