A 29-Second Delay Investigation Record
一次关于“29秒延迟”的排查记录
发现现象
The Observation
我的Aqara G4可视门铃在实时画面中,水印时间总是比手机系统时间晚29秒。起初我以为只是网络卡顿,但在不同时间、不同网络条件下测试,延迟始终固定在29秒。竖屏时水印字体太小看不清,横屏时手机状态栏又消失了——无法同屏对比,这个设计本身就有问题。
My Aqara G4 video doorbell showed a consistent 29-second delay between the watermark timestamp and my phone‘s system time during live view. I initially assumed it was network lag, but the delay remained fixed across different times and network conditions. In portrait mode, the watermark was too small to read; in landscape mode, the phone’s status bar disappeared — making it impossible to compare the two times on the same screen. The UI design itself made troubleshooting difficult.
向客服“报案”
Reporting to Customer Support
我向Aqara客服反馈了这个问题。他们说这是“第一次收到此类反馈”,并启动了远程诊断,需要3-5个工作日。这说明我的观察可能触及了一个他们测试中未覆盖到的盲区。
I reported the issue to Aqara support. They said it was the “first time they had received such feedback” and initiated remote diagnostics, requesting 3-5 business days. This suggested my observation had uncovered a blind spot in their testing.
与DeepSeek的讨论
Discussion with DeepSeek
我把现象告诉了DeepSeek。它提醒我:如果多个不同品牌、不同地域的设备都出现相同延迟,问题可能不在设备本身,而在于手机端获取时间的方式。它建议我检查手机的系统时间设置——尤其是“自动设置”开关是否开启。
I shared my findings with DeepSeek. It pointed out that if multiple devices from different brands and regions all showed the same delay, the issue likely lay not in the devices themselves, but in how the phone retrieves system time. It suggested I check my phone‘s time settings — specifically, whether “Set Automatically” was enabled.
交叉验证
Cross-Verification
我进一步验证:我在国内和欧洲各有一台华为摄像头,它们的实时画面也存在相同的29秒延迟。三台设备、两个品牌、两个大洲,问题一致——这几乎排除了设备本身或区域网络的嫌疑。
I cross-checked further: I have two Huawei cameras — one in China and one in Europe. Both showed the exact same 29-second delay on their live feeds. Three devices, two brands, two continents — the consistency all but ruled out device-specific or regional network causes.
问题解决
Resolution
我将手机时间与时区改为“自动设置”,问题立刻解决。实时画面延迟降至1秒左右,属于正常的网络传输延迟。三个设备全部恢复正常。
I switched my phone‘s time and time zone settings to “Set Automatically” — and the issue vanished instantly. The live feed delay dropped to about 1 second, which is normal for network transmission. All three devices returned to normal operation.
总结
Conclusion
问题根源很简单:手动设置时间会导致App获取时间戳时产生固定偏差。但这个简单原因之所以难以发现,是因为:一是普通用户很少会注意到水印时间,二是App的设计本身就让时间对比变得困难——竖屏看不清,横屏没法看。我的经验是:排查智能设备问题时,别忘了检查手机自身的“自动时间同步”功能。
The root cause was simple: manually setting the time caused a fixed offset when the app retrieved the system timestamp. Yet this simple cause was hard to uncover — because most users rarely notice the watermark time, and the app‘s UI itself made comparison difficult: too small in portrait, hidden in landscape. My takeaway: when troubleshooting smart devices, don’t forget to check your phone‘s own “automatic time sync” setting.
致谢
Acknowledgments
感谢Aqara客服的耐心配合,也感谢DeepSeek提供的精准方向。解决问题的关键,往往不是设备本身,而是那些我们默认“不会有问题”的细节。
Thanks to Aqara support for their patient assistance, and to DeepSeek for pointing me in the right direction. The key to solving a problem often lies not in the device itself, but in the details we assume “couldn‘t possibly be the issue.”
Hello, thank you for such an extensive description of how to fix the problem.
