After struggling with integrating my Velux Covers into Home Assistant via the KIG 300 gateway, I thought it would be helpful to share my step-by-step guide. This process might seem daunting at first, but with patience and attention to detail, it’s entirely manageable. Here’s how I did it:
1. Integrating the Gateway
- Reset the KIG 300 Gateway: Press the config button until the LED turns red, then release it.
- Connect to Wi-Fi: Use the Velux Active App (I recommend the iOS version) to bring the gateway into your Wi-Fi network.
- Restart Home Assistant: Once the gateway is connected, restart your Home Assistant host. This ensures the new device is recognized.
- Enter Activation Code: After restarting, a new Homekit device should appear in the HA frontend. Enter the activation code found on the gateway’s backside.
2. Adding Covers
- Pairing the Remote: Press the window symbol on the remote for 10 seconds, release, then press it again briefly. This ensures the remote is paired with the cover.
- Pairing the Cover: Open the window, press the pairing button outside for 10 seconds, then press the window button on the remote for less than a second. The cover should now be paired and visible in the Velux Active App and Home Assistant.
3. Troubleshooting Tips
- If the covers aren’t showing up in Home Assistant, double-check the pairing process and ensure the gateway is correctly integrated.
- If you encounter any issues with the remote or app, restarting both the gateway and Home Assistant can often resolve the problem.
4. Why This Matters
Having my Velux Covers integrated into Home Assistant has transformed my smart home experience. Now, I can control my blinds seamlessly from the HA frontend, create automations, and even integrate them with other smart devices. It’s a small but significant upgrade that adds to the overall convenience of my home.
I hope this guide helps anyone else looking to integrate their Velux Covers. If you have any questions or run into any issues, feel free to reach out! Happy automating! ![]()
