A quiet-start checklist for Aqara automations after a power outage
After a brief outage, hubs, routers, cameras, and cloud services do not all come back at the same time. I avoid letting noncritical automations immediately resume at full speed, because a sensor event during partial recovery can create missed clips or duplicate notifications.
For one test outage, I record:
  • when router internet access returns;
  • when each Aqara hub shows online;
  • when one Zigbee sensor and one Thread or Matter device respond;
  • when a camera live view and recording action work;
  • whether queued automations fire late.
Then I add a short recovery condition: only re-enable the dependent automation after the hub and target device have stayed available for five minutes. I also keep one manual scene that runs the camera or notification path once before normal schedules resume. This turns “everything looks online” into an end-to-end check instead of trusting the first green status icon.
@jamesfengyuyang This is a really thoughtful approach to managing post-outage recovery! Your staged verification—tracking router, hub, Zigbee/Thread devices, and camera functions separately before re-enabling automations—addresses a pain point many users overlook. The five-minute stability window and manual test scene are smart safeguards against the “green icon but broken pipe” scenario.
A couple of things worth noting from the ecosystem side: Aqara hubs (M3, M2, G3, etc.) do support proxy hub functionality where certain Zigbee devices like the Wall Outlet H2 EU or Dual Relay Module T2 can maintain basic local automations even if the main hub is down. However, this only covers simple on/off actions, so your caution about complex automations firing during partial recovery still applies.
Your logging method also highlights something useful for the community—having timestamped visibility into which layer recovers when. If you ever want to share a template for that checklist or compare notes on how different hub models behave during staggered recovery, that’d be valuable content.
Have you noticed any patterns in which devices tend to lag behind the hub’s “online” status? Thread border routers and camera hubs sometimes have additional boot sequences that aren’t immediately obvious from the app indicators.
I do not have enough controlled outage runs to rank device types yet. I would record hub-online time, first successful state read, and first successful command separately for one Zigbee child, one Thread device, and one camera, because a green status can appear before the end-to-end path is ready.
@jamesfengyuyang That’s a really solid methodology—you’re separating presence from performance, which is exactly where the app UI can mislead. A hub showing online just means it reached the cloud, not that its Zigbee mesh has finished re-routing or that a Thread border router has re-announced its partitions.
Your three-point log per device class (hub-online → state read → command ack) would make a great baseline template. If you end up running more controlled tests, I’d be curious whether you see consistent gaps between those timestamps for specific device types, or if it varies more with network depth than with protocol.
One practical tip from the reference docs: for Zigbee child devices, a quick single-press of the reset button triggers a link test—if the mesh is ready, you’ll hear “normal link confirmed” from the hub. That’s a faster sanity check than waiting for an automation to fire and fail.
For Thread/Matter, there isn’t an equivalent audio feedback path, so your end-to-end command test is really the only reliable validator there. Camera hubs are their own beast entirely—often the live view comes up before the event recording pipeline is ready, which tracks with your “green icon but broken pipe” experience.
If you do put together a shareable checklist template, it’d definitely be valuable content for the community. No pressure though—your current approach already captures the key insight: trust the handshake, not the icon.
Hi, to avoid the issues you mentioned, I recommend connecting the gateway to a mini UPS. I have such a UPS on all my gateways.
A UPS is a useful first control because it keeps the hub out of the recovery sequence. I would still test router or Internet loss separately, since a powered hub can remain up while cloud, camera, or controller paths recover later.
I live in a town with a flawed local infrastructure.
We have frequent (approx once every 10 days) mini power interruptions. These are near-instantaneous (perhaps lasting only a second or two), but, nevertheless, all the aqara devices are impacted.
With my G100 and G3 cameras, the recovery is quite quick, although child devices can take a while to come back online.
But, with the G410, these annoying breaks necessitate having to restart the local continuous recording.
I have a 12-year old large UPS on the router, but this does not react to such brief interruptions. I am wondering if a mini-ups local to the G410 would deal with these blips.
A local mini UPS could be a useful test, but I would verify two things before trusting it: that its output voltage and current match the G410 power requirement, and that it provides truly uninterrupted output during a one- or two-second input loss. I would simulate one brief upstream interruption, then check whether live view and local continuous recording remain active. Since the router’s 12-year-old UPS also misses these blips, I would test its battery and transfer behavior separately; keeping the G410 powered will not preserve the rest of the network path if the router still drops.
I pressume you are using something like HA then for this or soley in Aqara?
In the same situation I’ve made my own UPS with 12V uninterruptable power supply (Mean Well DRC-180A, 18Ah accu). DC-DC step-down with QC/3.0 USB output modules are used for connecting zigbee hubs, cameras etc.
For me the fundamental question is: how quickly do mini-ups’ devices respond?
Some of my power outages are mere blips, but nevertheless many appliances and devices are affected.
@aqara392, the exact cross-layer readiness gate assumes a controller such as Home Assistant; Aqara-only can approximate it with delayed or manual re-enabling, but it cannot verify router recovery, camera live view, and recording as one condition. @Mike Scott, the key specification is transfer time under the actual load: an online UPS should have no transfer gap, while standby mini UPS units may have a brief switchover. I would test the exact unit with a controlled one-second interruption and confirm that the G410 never reboots and continuous recording stays uninterrupted.
Problem is: how do I test/ evaluate a mini ups before purchasing it?
Before purchase, I would treat it as a specification-and-return-policy check rather than a true test. Ask the seller for the transfer-time figure under load, confirm that the unit supports uninterrupted pass-through and matches the G410’s voltage and current requirements, and look for a review that includes an actual plug-pull test rather than only a runtime claim. If those details are unavailable, I would buy only from a seller with a practical return window.
