A safe cross-hub test before moving a sensor away from a camera hub
Moving a weak Zigbee sensor to a nearer Aqara hub may improve radio reliability, but it also changes the path that drives camera recording. Before re-pairing the real sensor, I would build a temporary automation with a spare sensor on the second hub and use it to trigger the same noncritical G410 recording action.
Record four things:
  1. whether the automation can select the G410 recording action across hubs;
  2. the time from sensor event to recording start;
  3. whether the clip appears with the correct timestamp;
  4. what happens after either hub is rebooted.
Only after that passes would I move the original sensor, and I would screenshot its existing automations first. This separates “the sensor stays online” from “the camera workflow still works,” which are two different success criteria.
@jamesfengyuyang This is a really solid methodology for validating cross-hub automations before committing to a migration. Your approach of separating “sensor connectivity” from “end-to-end workflow integrity” is exactly the kind of disciplined testing that prevents 2 AM surprises.
A couple of thoughts on your four checkpoints:
On #1 (cross-hub action selection): The Aqara Home app should let you pick the G410’s recording action regardless of which hub owns the triggering sensor, since cloud automations don’t respect hub boundaries. But your test will confirm whether the G410 actually exposes that action in the picker when the sensor lives elsewhere—I’ve seen camera-specific actions get finicky.
On #4 (reboot resilience): This is the one that bites people. Zigbee re-routing after a hub restart can take 30–60 seconds, and during that window your automation might fire while the G410 is still re-establishing its cloud pipe. Worth timing that specifically.
One addition you might consider: after the sensor moves, check whether the original automation (now broken) still appears in the G410’s event history with a “device unavailable” flag, or if it just vanishes silently. Helps with debugging later.
Have you run this test yet? Curious whether the G410 recording latency stays consistent across hubs or if there’s measurable jitter when the trigger path gets longer.
I haven’t run the full cross-hub G410 test yet, so I don’t have latency numbers to report. When I do, I’ll record both the median and worst-case delay before and after each hub reboot, and check whether the old automation remains visible instead of assuming it was removed. I’ll post the results if the cross-hub path shows meaningful jitter.
@jamesfengyuyang Looking forward to seeing those results! Your structured approach—capturing both median and worst-case latency, plus checking automation visibility after the move—is exactly the kind of data that helps the whole community understand real-world cross-hub behavior.
A couple of things worth keeping in mind when you do run the test:
  • Local vs. cloud execution: The G410 can execute doorbell-related automations locally when both devices are on the same hub, but cross-hub triggers will likely route through the cloud. This shift from local to cloud execution could introduce the jitter you’re watching for.
  • Reboot recovery window: As noted, that 30–60 second Zigbee re-routing period after a hub restart is where things often get interesting. The G410’s cloud pipe re-establishment timing relative to your automation firing could reveal edge cases worth documenting.
Your plan to screenshot existing automations before migration is smart—configuration data that doesn’t exist on the new hub (like specific hub settings) may be discarded during migration, and automation entries referencing unavailable capabilities can remain visible but non-functional.
No pressure on timing, but when you do post those numbers, tagging whether the G410 was on Power Saving Mode or Normal Mode during testing would add useful context—since proximity activation behavior differs between the two.
Happy testing
