As a homeowner deeply invested in creating a smart living environment, I’ve always been fascinated by the potential of automation to simplify daily life. My latest project has been setting up a system to automatically close my curtains based on both temperature and the sun’s position, a feature I’ve seen demonstrated in various forums and tutorials. While the concept seemed straightforward, the execution proved to be a bit more complex than anticipated.
I started by researching how to integrate weather data and sun position into my Home Assistant setup. The idea was to have the curtains close when the temperature rises above a certain threshold and the sun is in a specific position, thereby reducing heat gain and keeping my home cooler naturally. I found some excellent resources in the community, including detailed explanations of how to use numeric_state triggers and conditions in automations.
However, translating these concepts into a functional automation wasn’t without its challenges. I spent hours tweaking the trigger and condition logic, trying different combinations of platform: state and platform: numeric_state. One hurdle was ensuring that the automation correctly interpreted the sun’s azimuth data and the temperature readings. I also had to consider how to handle edge cases, such as cloudy days or when the sun was on the horizon, which required additional conditional checks.
Through trial and error, I discovered the importance of carefully structuring the conditions and ensuring that the triggers were properly nested. For instance, I learned that using an or condition for weather states like sunny or partly cloudy was essential to cover a broader range of scenarios. I also realized that testing each component of the automation individually before combining them was crucial for troubleshooting.
After several iterations and a lot of logging, I finally achieved the desired behavior. The curtains now close automatically when the temperature exceeds 25°C and the sun is in the correct position, and they reopen when the conditions no longer apply. It’s a small victory, but it’s incredibly satisfying to see the system working as intended.
This project has reinforced my belief in the power of community-driven solutions and the importance of persistence when tackling complex automation tasks. I’m already brainstorming my next project—perhaps integrating a similar system for my backyard lights or pool heater. The possibilities are endless, and I’m excited to continue exploring what Home Assistant can do!
If anyone has tips for optimizing automation logic or suggestions for similar projects, I’d love to hear them! Let’s keep the learning and innovation going!
