Achieving Stable Humidity and Perfect Lighting Automation
As a passionate user of smart home technology, I’ve been on a journey to optimize my indoor growing environment. One of the most critical aspects of this setup is maintaining stable humidity levels, which are essential for plant health. My goal is to keep humidity between 61-62%, and while I’ve managed to achieve this most of the time, there’s an annoying fluctuation every 20 minutes that I’m determined to fix.
I’ve been using the History Explorer custom card to monitor humidity, and it’s been a great tool. The green line representing humidity is usually within the desired range, but every 20 minutes, it fluctuates between 61-65%. This is clearly caused by the automated dehumidifier, and I want to fine-tune the automation to eliminate these fluctuations.
To tackle this, I think creating a boolean sensor would be really helpful. This sensor would indicate two states: ‘Stable’ when humidity oscillates within 1%, and ‘Unstable’ when it exceeds 1%. I’m curious if anyone has experience creating such a sensor in their configuration.yaml file. Any tips or guidance would be greatly appreciated!
On another note, I’ve also been experimenting with lighting automation for my growing room. I’ve set up a system where the lights dim slightly during the night to mimic natural conditions, and they brighten up again in the morning. This has been working well, but I’ve noticed that the transition could be smoother. I’m considering integrating a scene that gradually adjusts the brightness over a set period. Does anyone have experience with similar setups or suggestions for improvement?
Overall, it’s been a fascinating process learning how to balance automation with the specific needs of my plants. I’d love to hear from others who’ve tackled similar challenges or have innovative ideas to share. Let’s keep the conversation going and help each other create smarter, more efficient home environments!
Cheers,
