Hey everyone! I’ve been diving into the world of smart home automation lately, and I must say, it’s been an incredible journey. One thing I’ve been particularly excited about is integrating Alexa with my existing smart home setup. I wanted to share my experience and a little tip I discovered that might help others out there.
So, my goal was to create a seamless two-way automation between Alexa and Home Assistant. Specifically, I wanted to set up an alarm clock that I could control both through Alexa voice commands and the Home Assistant UI. At first glance, it seemed straightforward, but there were a few hurdles I needed to overcome.
I started by setting up an Input_DateTime entity in Home Assistant to handle the alarm time and an Input_Boolean to toggle the alarm on and off. Then, I created an automation in Alexa to trigger the alarm based on my voice command. It worked, but there was a catch—it didn’t update the Input_DateTime in Home Assistant. This meant that while Alexa could set the alarm, the UI didn’t reflect the changes, which was a bit frustrating.
After some research, I stumbled upon a solution that involved using the as_timestamp function to format the time correctly. Here’s how it worked:
{{ as_timestamp(states(‘sensor.gym_echo_dot_next_alarm’)) | timestamp_custom(‘%H:%M’) }}
This little snippet allowed me to extract the time from Alexa’s sensor and format it in a way that Home Assistant could understand. The key was ensuring the time format matched between Alexa and Home Assistant. Once I got that right, the Input_DateTime entity updated seamlessly, and the alarm was set correctly in both systems.
I was thrilled when it finally worked! It’s those small victories that make the learning curve totally worth it. Now, I can set my alarm either through Alexa or the Home Assistant UI, and both stay in sync. It’s such a neat integration, and I can’t wait to explore more possibilities like this.
If anyone else is working on similar automations or has tips to share, I’d love to hear about them! Let’s keep the smart home community growing and thriving. ![]()
