I’m curious to see if anyone here is using Aqara or other smart-home devices alongside a reef aquarium.
I’ve got a reef tank at home and, naturally, I’m now wondering what else I can make smart!
Obviously there are the basics like smart plugs for monitoring power consumption and controlling equipment, but has anyone found any more interesting uses?
Things like:
• Temperature monitoring and alerts
• Leak detection around the tank or sump
• Water-level monitoring
• Cabinet/sump lighting
• Automated feeding
• Monitoring pumps and other equipment
• Notifications if something stops working
• Automations linked to lighting or maintenance routines
I use Home Assistant as well, so I’m particularly interested in anything that can be integrated into a bigger smart-home setup.
Has anyone built anything clever around their aquarium? It doesn’t necessarily have to be an Aqara product — I’d love to see what gadgets, sensors and automations people are using.
Bonus points for the completely unnecessary automations that somehow became essential.
@francism1984 What a fun project!
A reef tank is basically begging for smart-home magic, and it sounds like you’re already thinking like a true automator.
From the Aqara side, you’ve got some solid building blocks for your setup. The Water Leak Sensor is an obvious win for sump or cabinet leak detection — it can be placed directly on the surface or wired with extension cables to cover more ground. Pair that with an automation to push alerts and play an alarm through a hub like the Hub M2, and you’ve got peace of mind when you’re not hovering over the tank.
For temperature and humidity monitoring, Aqara’s Temperature and Humidity Sensor slots nicely into that “summer automatic temperature and humidity control” automation pattern — trigger a smart plug to kick on a cooling fan or even an A/C unit if things get toasty.
Your smart plug idea for power monitoring and pump control is spot-on too. Aqara plugs can track consumption and be automated on schedules or sensor triggers, which ties into those maintenance routines you’re after.
Since you’re running Home Assistant, you’ve got way more flexibility than most. Aqara’s Zigbee sensors and plugs play nicely with HA via a compatible hub, so you can build those completely unnecessary-but-now-essential automations — like a “feeding mode” scene that dims tank lights, pauses pumps briefly, and logs it to a dashboard. Or cabinet lighting that fades on when you open the stand door.
The Aqara Cube is a surprisingly fun controller for this kind of thing too — rotate to adjust cabinet light brightness or color temp, flip it to trigger a water change routine.
Would love to hear what you end up building! The crossover between reef keeping and home automation always produces the most satisfying (and slightly obsessive) setups.
