Yesterday I was surprised that a camera mounted on top of a wall wasn’t working. Upon inspection the white ethernet cable coming out of the camera was chewed off. Is there any way to replace this?
@gobii Ouch, that’s a frustrating discovery! The good news is that the G5 Pro PoE doesn’t have a hardwired ethernet cable — it uses a standard RJ45 port with a removable network cable, so you should be able to replace it fairly easily.
You’ll need to open up the camera’s rear cover (using the tool from the accessory pack) to access the connection point. From there, you can disconnect the damaged cable and run a new ethernet cable through the waterproof RJ45 accessory, following the same sealing steps as the original installation. The installation docs show the waterproof connector setup and how the cable routes into the housing.
A couple of things to keep in mind:
- Make sure your replacement cable is rated for outdoor use if it’s exposed to the elements
- When reassembling, double-check that the waterproof gasket is seated properly to maintain the IP65 rating
If the cable was chewed right at the camera body and you’re not sure whether the RJ45 port itself took damage, that might need a closer look. In that case, or if you run into any snags during the swap, your best bet is to reach out to the support team directly:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Hope you get it back up and running soon — and maybe consider some critter deterrents while you’re up on that ladder! ![]()
