APC UPS Firmware Update Solution
Hey everyone, I wanted to share my recent experience with updating the firmware on my APC Smart-UPS. It was a bit of a rollercoaster, but I managed to figure it out, and I hope this helps someone else avoid the frustration I went through.
So, the issue started when I tried to update the firmware on my APC SMX1500RMI2UNC unit. I followed the usual steps—using the Network Management Card (NMC) to initiate the update through the web interface. Everything seemed to be going smoothly at first, but then the UPS got stuck in a restart loop. The LEDs were blinking, and the front panel displayed ‘firmware update in progress.’ I could tell something was wrong, but I wasn’t sure what to do next.
I checked the event log and saw several error messages related to the firmware transfer failing. It looked like the NMC was having trouble communicating with the UPS during the update process. I tried a few troubleshooting steps: reinstalling the firmware update tool, disabling auto-detection, and manually specifying the COM port. Nothing worked. The UPS remained unresponsive, and I was worried it might be permanently bricked.
After some research, I discovered that in cases where the NMC fails, you can manually update the firmware using a serial connection. I grabbed a serial-to-USB adapter, set up a terminal emulator with the correct settings (9600 baud, 8 data bits, no parity, xon/xoff flow control), and connected it to the UPS. Using the XModem protocol, I managed to transfer the firmware file directly to the UPS. It was a bit nerve-wracking, but it worked! The UPS rebooted, and the firmware update was successful.
This experience taught me two valuable lessons: first, always have a backup plan when dealing with firmware updates, and second, don’t give up too easily. Sometimes, a little persistence and a willingness to try alternative methods can save the day.
I’d like to thank the APC community for their helpful forums and documentation. It was a lifesaver during this troubleshooting process. If anyone else runs into similar issues, I hope this post gives you the encouragement to keep going and try those alternative solutions.
Happy updating, and here’s to hoping your firmware updates go more smoothly than mine did!
Cheers,
Colin
