Apple HomeKit on IOS17 showing higher resolution natively with G410?
Hi guys,
Does anybody know for sure that if you upgrade your IOS to IOS17 that you get to see a better resolution through the HomeKit app on your phone? Debating whether to upgrade or not.
Thanks.
@theboychris Hi there! Thanks for bringing up this interesting question about iOS 17 and the G410 resolution.
Currently, the maximum resolution for the Aqara Doorbell Camera Hub G410 in the Apple Home app is restricted to 1600×1200p due to limitations of the HomeKit platform, rather than being tied to a specific iOS version. Even if you upgrade to iOS 17, this hardware and platform encoding limitation remains, so you likely won’t see a native resolution increase specifically from the OS update alone.
However, upgrading to the latest iOS is generally recommended for overall security and stability, especially if you want to ensure your HomeKit hub and cameras are communicating properly. If you are only using the Aqara Home app (without HomeKit), the G410 can support up to 1536p, but once added to HomeKit, it drops to the 1600Ă—1200p limit.
If you’re experiencing any specific issues after an update or have other questions about your smart home setup, feel free to share!
Can we assume you ment to say iOS27 ? because that is the current operating system for the phone that was released this month.
