Aqara automations using Apple home
Help @AqaraBot
I have an automation using Apple Home where the Aqara security system activates at 19:30 and deactivates at 06:10.
Over the last couple of days I’ve noticed that even tho the automations are set up the security system activates at 19:00 and deactivates at 06:10.
What makes it even stranger is if I activate/deactivate is straight away the system will activate/deactivate the correct time, but the next day the system will activate/deactivate at the wrong time again.
I’ve spoken to Apple and they advised that because all other automations (none Aqara) come on and off at the correct time, the issue is down to Aqara.
I’ve emailed support but can you help ?
I
Hello, checked the automation log. Often users create automation that then produces such effects.
I’ve checked the automation log and it shows the automation both day and night activating/deactivating early.
As soon as I re activate/deactivate it within seconds of it triggering early, the log shows that and then activating:deactivating at the correct time
Show screenshot
