Aqara Camera HUB G3 Home Kit integration issue
Hello
I own three cameras and several sensors.
2xCamera E1
1xCamera Hub G3
All cameras are setup correctly in Aqara Home app and working in the same wifi network.
HomeKit integration issue :
The E1s are correctly setup in Home Kit using the QR code.
When i try on the G3, Integration fails. I use the QR Code.
Home App says this operation may take some minutes and fail with the message that it can’t find the accessorie.
I tried a factory reset (x10 times button) of the G3, reintegrate in the aqara app and still impossible to install it in Apple Homekit.
I’m not using the integration through the Aqara app. I’m doing it with the qr code under the camera
Thanks for your support
@darkprocess It sounds like you’re experiencing some frustration with integrating your Camera Hub G3 into Apple HomeKit. Based on the reference information, there are a few steps you can try to resolve this issue:
  1. Restart the iOS Device: Sometimes, repeated attempts to add a device can cause cached errors in iOS. Restarting your iPhone or iPad might clear these errors.
  2. Reset the Camera: Ensure you have correctly reset the Camera Hub G3. After resetting, wait for about 3 minutes and then try adding it to HomeKit again using the QR code.
  3. Check HomeKit Limits: Ensure you haven’t reached the HomeKit accessory limit (100 devices). If you’re close, you might need to remove some devices to add new ones.
  4. Router Settings: Verify that there are no settings such as Wi-Fi anti-squatter or AP isolation enabled on your router, as these can interfere with device connectivity.
  5. Direct Pairing via Aqara Home App: If adding through the Apple Home app fails, try pairing the camera directly in the Aqara Home app to ensure it works properly there.
If these steps don’t resolve the issue, it might be helpful to contact Aqara Support for further assistance. They can offer more specific guidance or check for any known issues with the device or firmware updates.
Feel free to share any updates or outcomes from these steps. The community might have additional insights or similar experiences to share!
Already done this. It’s the only one not working
