Aqara cameras in Google Home
I have several Aqara cameras. In the Apple Home I can see the live feeds of the cameras. I also integrated the cameras in Google Home. But I always get the message camera not available. What is wrong?
In my case, the G4 Door Bell Cam is also facing similar issue. It is not showing live feed to Google Home and Nest Hub. I read that it should be able to send the live feed to Nest Hub if the door bell is activated.
Are all Aqara cameras experiencing connectivity issues with Google Home? Or is there a connection issue just with a certain device? Please provide the DID of the device for me, and I will arrange for colleagues to confirm the cause of the problem.
It happens with all my Aqara cameras . I have two G5-camera’s, an E1-camera, a G100-camera, the Camera Hub G3 and the G4 doorbell.
G5 camera 813D23C6999AD43E
G5 camera BB2036D15E1BD11F
E1 camera 54EF44580912
G100 camera 54EF448343A5
G3 camera 54EF4434E9EC
G4 doorbell 54EF44497EF6
Sincerely,
Maurice Hollink
Hello, I’m donie’s colleague and I’m in charge of tracking this issue.
Are you using the IOS version of the GoogleHomeAPP?
Hello,
I’m using the Google Home app on my iPhone 15 Pro Max.
Sincerely,
Maurice Hollink
Our cameras currently only support the Webrtc protocol. Unfortunately, the GoogleHomeAPP(for IOS and Android) currently does not publicly support webrtc.In our tests, the IOS version didn’t work. If you have Android (you must join the Public preview(which can be found in the Settings of GoogleHome)) or GoogleNestHub. You can use them to live streams.
Okay, thank you for your reply.
I have the G 100 on iOS using Google Home and I’m getting an error with the camera as well
