Aqara cube T1 pro
So is it just me or does the rotation on Aqara Cube T1 pro break sometimes? I don’t know if my cube is just broken or if it’s supposed to be like that?
Could you please give us more details about your Cube T1 pro issue?
So that we can check what can we help
I have it connected in Homey (not through an Aqara Hub M3 as i don’t think matter for Cube T1 Pro is out?) and sometimes the rotatiin action won’t respond. The cube t1 pro is connected in Homey through the aqara app in the homey app store. (Zigbee)
We would highly recommend that you connect the device to the Aqara Home app in order to explore its full functionality and features. Please note that in order to do this successfully, you will need to have an Aqara hub at the same time, as the Aqara cube controller T1 pro does not support direct connections to the Aqara Home app without the hub. This setup will allow you to make the most out of your device and manage it efficiently through the app.
Yes, but i use the cube for my Homey flows, i do have a Aqara M3 Hub which i use to get matter devices from Aqara over to Homey, but as the cube t1 pro doesn’t support matter yet i have it connected through the aqara app in the homey app store.
