After spending considerable time researching and troubleshooting, I’m thrilled to share my successful integration of the Aqara Doorbell G410 with my Google Nest Hub. My goal was to achieve simultaneous alerts across three layers: the physical chime, mobile notifications, and the smart display. While the process had its hurdles, the community’s support and insights were invaluable.
Initially, I was unsure if the G410 natively supported visitor announcements on the Google Nest Hub. I reached out to the forum, and several users confirmed that it works out-of-the-box. However, the video feed doesn’t appear automatically—it only sends a voice announcement. For the physical chime, I had to ensure the doorbell was properly configured to trigger the Nest Hub alert simultaneously.
One challenge I encountered was the delay between the physical chime and the Nest Hub alert. After experimenting with different settings and consulting the forum, I discovered that adjusting the doorbell’s sensitivity and ensuring a stable Wi-Fi connection significantly reduced the delay. I also explored using IFTTT for additional automation but found that the native integration was sufficient for my needs.
I’m now enjoying a seamless alert system where pressing the doorbell triggers the chime, sends a push notification to my phone, and announces the visitor on my Nest Hub. The integration feels polished and reliable, and I couldn’t be happier with the outcome. A huge thank you to the community for their guidance and support!
This experience has taught me the importance of thorough research and the value of community collaboration in achieving a well-integrated smart home setup.
