Aqara Floor Lamp T1 Review
The Aqara Floor Lamp T1 is an intelligent lighting solution designed to fill your walls with RGBIC color and up to 1000 lumens of white light. After unboxing, assembly, and daily use, here are my impressions.
Unboxing and Physical Install
The lamp arrives in nice, simple packaging with items packed efficiently and clear instructions.
Assembly is generally straightforward, though the base requires a bit more force than expected to pop in snugly. One minor annoyance during setup involved the stickers covering the screw access points on the rods. They were difficult to remove and felt unnecessary.
Additionally, the material of the light strip tends to attract dog hair easily. Hasn’t been an issue since it was placed in it’s spot.
Setup and Connectivity
Connecting the lamp via Matter over Thread was a piece of cake. It offered instant recognition and pairing in both the Aqara app and Apple Home. Once connected, Apple Home immediately suggested enabling Adaptive Lighting by default. While the power adapter works fine, a standard USB C connection would have been a better choice.
Performance and Lighting
During the day, the lamp provides a nearly uniform white color pattern that complements rooms with heavy sunlight exposure.
At night, the light diffuses beautifully when pointed toward a corner wall.
When facing the room directly, some light banding is visible when using colors, though this is expected and comparable to other quality brands like Govee.
Apple Home Integration
While the Aqara app retains access to dynamic lighting and RGB effects in Matter over Thread mode, this review focused on Apple Home as the primary use case. The integration is excellent. Colors adjust fluidly, dimming controls react reliably, and both scene setting and automation controls work exactly as expected.
The Aqara Floor Lamp T1 is an impressive offering. The painless pairing process and granular brightness controls make it a joy to use. While having gradient controls directly inside Apple Home would be wonderful, this is likely a limitation of the current Matter protocol rather than the hardware. Ultimately, this lamp is a fantastic alternative to existing options on the market, particularly for those already invested in the Aqara ecosystem. After almost a couple months of use, we are very happy with it and have encountered zero issues.
