@dlpsr Thanks for sharing your FP300 setup journey! It’s awesome to hear you snagged one on Amazon and had a smooth experience pairing it with Z2M and HAOS—your real-world tips will definitely help others feeling hesitant about the process.
For that permanent mounting spot you’re considering, the FP300 has some handy installation recommendations: if you need broader coverage, mounting it around 2 meters high with a slight downward tilt works well, while wall or corner setups at 1.4–1.8 meters are great for covering both standing and seated positions. Also, try to avoid placing it near large metal/glass surfaces or air vents to keep detection reliable.
Looking forward to hearing how the battery performs over time and where you end up installing it—don’t hesitate to share updates later!
