Aqara FP2 in Home Assistant — The Guide That Actually Works
Getting the Aqara FP2 into Home Assistant
Using ha-aqara-devices + aqara-rocketmq-bridge
Background
I am running Homekit/HomeBridge in my Smart Home. I recently began dabbling with Home Assistant. It is a very powerful tool that exposes way more than HomeKit. That being said, it can also be very overwhelming. The problem the led me to write this post was that although I have started to use Home Assistant, HomeKit/HomeBridge is still my main ecosystem. My priority is to have everything in HomeKit. Then and only then, will I also want my devices in Home Assistant as I continue to play with it and learn. The issue I ran into was that I had my Aqara FP2 Sensor in HomeKit and as long as it was connected to HomeKit I could not add it to Home Assistant. I believe, I had the option of deleting it from HomeKit, adding it to Home Assistant, and then exposing the device’s entities to HomeKit via the HomeKit Bridge. In my case, I did not want to lose all my settings, automations, scenes, etc. associated with my FP2 just to be able to add the FP2 to both ecosystems. The solution is the community-built ha-aqara-devices custom integration paired with the aqara-rocketmq-bridge, which use Aqara’s Open API v3 to deliver live presence updates to Home Assistant. You should also note that this would also apply to the FP300, Hub M3, and the Hub G3.
Useful Links
• Official Setup Guide: Setup Guide | Aqara RocketMQ Bridge
• Bridge Repository: GitHub - Darkdragon14/aqara-rocketmq-bridge: Aqara RocketMQ bridge for Home Assistant · GitHub
• HA Integration Repository: GitHub - Darkdragon14/ha-aqara-devices: Custom Home Assistant integration for Aqara devices. Supports Hub G3, Hub M3, FP2 and FP300 via Aqara Cloud with advanced controls, presence telemetry and extended features beyond the official integration. · GitHub
• Aqara Developer Console: https://developer.aqara.com/
How It Works
Aqara RocketMQ → aqara-rocketmq-bridge → SSE → ha_aqara_devices → Home Assistant
The bridge consumes Aqara Message Push events via RocketMQ and exposes them to Home Assistant over Server-Sent Events (SSE). The integration manages authentication, token refresh, and entity creation.
Step 1 — Aqara Developer Account
Go to https://developer.aqara.com/ and sign up using the same email or phone number as your Aqara Home app account. This is important — your FP2 must be in the same account tied to the developer project.
Tip: When you sign up, you are automatically given access to a Demo Project. This is sufficient for personal/home use and does not require any special approval.
From the Demo Project, collect these three values:
Value Where to Find It
APP_ID Project overview / dashboard page
KEY_ID Key Management section
APP_KEY Key Management section
Step 2 — Configure Aqara Message Push
Inside your project, go to Message Push and configure the following:
• Select Get messages based on message queue
• Select your Key ID
• Enable push
• Set subscription mode to All receiving mode (Resource) — see important note below
• Copy the MQ message subscription address — this is your MQ_NAMESRV_ADDR
Note: The official docs recommend User-defined subscription mode, but this requires calling config.resource.subscribe, which is blocked on Demo accounts and returns a 403 error. Use All receiving mode (Resource) instead. This bypasses the subscribe call and allows live updates to flow without any additional API permissions.
The Message Push values map to bridge environment variables as follows:
Aqara Message Push Field Bridge Variable
MQ message subscription address MQ_NAMESRV_ADDR
topic APP_ID
accessKey KEY_ID
secretKey APP_KEY
Do not use the example nameserver address shown in Aqara’s documentation. Always copy the exact MQ_NAMESRV_ADDR from your own Message Push page.
Step 3 — Choose a Bridge Token
The BRIDGE_TOKEN is not provided by Aqara — you create it yourself. It is a strong password that secures communication between Home Assistant and the bridge. You will enter the same value in both the bridge container and the HA integration config flow.
Step 4 — Run the RocketMQ Bridge
In my case, the bridge runs as a Docker container and I access my Home Assistant via DuckDNS. Add the bridge to your compose.yml under services:
  image: ghcr.io/darkdragon14/aqara-rocketmq-bridge:main
  container_name: aqara-rocketmq-bridge
  restart: unless-stopped
  ports:
    - "8081:8080" # Use 8081 if port 8080 is already occupied environment:
    APP_ID: your-app-id
    KEY_ID: your-key-id
    APP_KEY: your-app-key
    BRIDGE_TOKEN: your-chosen-token
    MQ_NAMESRV_ADDR: your-mq-address-from-aqara-console
    BRIDGE_PUBLIC_URL: https://your-domain.duckdns.org
Start the bridge:
    docker compose -f ~/compose.yml up -d aqara-rocketmq-bridge
Verify it is healthy:
    curl http://localhost:8080/health
Tip: A healthy response looks like: {“status”:“up”,“rocketmqEnabled”:true,“rocketmqStarted”:true,…}. Once messages flow from Aqara, lastMessageAt will show a timestamp.
Choosing the Right Bridge URL for HA
The Bridge URL is what Home Assistant uses to reach the bridge. The correct value depends on your HA network configuration:
HA Setup Bridge URL to Use
HA Container with network_mode: host http://YOUR_IP:8080 (e.g. http://192.168.1.XXX:8080)
HA Container on shared Docker network http://aqara-rocketmq-bridge:8080 (integration default)
Home Assistant OS add-on http://YOUR_HA_IP:8080
Note: If your HA container uses network_mode: host, it cannot resolve Docker container hostnames. The default http://aqara-rocketmq-bridge:8080 shown in the HA form will NOT work. Use your host machine’s local IP and the mapped port instead.
Step 5 — Install ha-aqara-devices via HACS
• HACS (Home Assistant Community Store) is a community-built add-on for Home Assistant that lets you easily browse, install, and update third-party integrations, themes, and plugins that aren’t part of the official Home Assistant release — think of it as an app store for your smart home.
• In HACS, go to the three-dot menu and select Custom repositories
• Add GitHub - Darkdragon14/ha-aqara-devices: Custom Home Assistant integration for Aqara devices. Supports Hub G3, Hub M3, FP2 and FP300 via Aqara Cloud with advanced controls, presence telemetry and extended features beyond the official integration. · GitHub as an Integration
• Search for Aqara Devices and install it
• Restart Home Assistant
Step 6 — Configure the Integration
Go to Settings > Devices & Services > Add Integration > Aqara Devices and fill in:
Field Value
Aqara account Your Aqara email or phone number
Region Match your Aqara Home app region (e.g. US)
Bridge URL http://YOUR_PI_IP:8081 (see Step 4)
Bridge token Your chosen BRIDGE_TOKEN from Step 3
App ID From Demo Project
App key From Demo Project / Key Management
Key ID From Demo Project / Key Management
After submitting, Aqara sends a verification code to your email or phone. Enter it on the next screen to complete setup. The code expires in 10 minutes.
API Quota
The Demo account allows 100,000 API calls per month. Estimated usage per device:
Device Est. API Calls / Month
FP2 ~43,200
FP300 ~25,920
Hub M3 ~8,640
Hub G3 ~17,280
One FP2 + one M3 = ~51,840/month, well within the free quota. Two FP2s would approach the cap.
FP2 Entities Available in Home Assistant
Platform Entities
binary_sensor Presence, Connectivity, Detection Area 1-30
sensor People Counting, People Counting (per min), Whole Area People Count (10s), Zone 1-30 People Count (10s), Zone 1-7 People Count (per min), Illuminance, Heart Rate, Respiration Rate, Body Movement, Sleep State, Operating Mode, View Zoom, Mounting Position, Installation Angle, Attitude Status, Presence Sensitivity, Proximity Distance, Fall Detection Sensitivity, AI Person Detection, Anti-light Pollution Mode
Troubleshooting
403 error on config.resource.subscribe — entities unavailable
The Demo account cannot call the subscribe API in User-defined mode. Fix: in the Aqara developer console, change Message Push subscription mode to All receiving mode (Resource), then delete and re-add the HA integration.
Authentication failed — no verification code screen appears
Check that APP_ID, APP_KEY, and KEY_ID are all from the same project. Try your phone number instead of email (format: +1XXXXXXXXXX). Confirm your region matches your Aqara Home app account region.
/health returns ‘starting’ instead of ‘up’
Verify Message Push is enabled in Aqara, the Key ID in Message Push matches your bridge KEY_ID, and MQ_NAMESRV_ADDR is the exact value from your own Message Push page, not the example from documentation.
Bridge unreachable from HA (host network mode)
If HA uses network_mode: host, Docker container hostnames are not resolvable. Use your host machine’s local IP and mapped port as the Bridge URL (e.g. http://192.168.1.XXX:8080).
Access Token errors after re-adding the integration
Each time you re-add the integration a fresh authorization is required. Go to the Aqara developer console, generate a new authorization code, and enter it when prompted. Codes expire in 10 minutes.
Guide based on real-world setup experience. For the official bridge documentation visit:
Great project! What a coincidence – I actually tried my hand at a similar project a few weeks ago. I’ve even already published the RocketMQ to MQTT Bridge as an app (add-on): HA_LaFeMa_Apps/rocket_mq_2_mqtt at master · lafema/HA_LaFeMa_Apps · GitHub
By the way, the call consumption estimates for the FP2 may be too conservative. The lighting conditions here are constantly changing at the moment as the sun and clouds keep alternating. This alone has resulted in a huge number of calls for me. In the last 12 hours, I’ve made around 5,000 calls. This suggests that the 2 million call allowance would be used up in about a year. Fortunately, though, we don’t have this sort of weather all year round. Let’s hope consumption returns to normal over the course of the year.
Amazing sharing! :100:
i was finally able to set up the add on! Thanks for your instructions!
Hi,
Thanks a lot for mentioning / referencing my integration in your guide, I really appreciate it!
If anyone is missing support for a specific Aqara device, feel free to open an issue here so we can track it properly:
Thanks again!
Hey @darkdragon14! Nice to see you here as well!
Thank you for your work!
I was thrilled to find your integration and it was my You are providing a
great service and it’s appreciated.
Thanks for the info but I’m still waiting (it has already been months) for the developer account to be “approved”. Not good.
Hello,
I got weird behaviour with my FP2 and Google Home… Sometimes Google executes the action even if the sensor does not seems to be sending the trigger. For example, no person detected in a certain area. Is there a known glitch for this?
Hello:
I was able to configure and setup everything according to the directions. Unfortunately, I am not receiving any real time push requests. None of my FP2 devices are updating. I have to reload the integration to see any changes in the sensor attributes. Any ideas would be appreciated.
Hello @US-EddieDaYankee
Thank you for the great work and sharing what you’ve put together.
I was able to follow your great directions to the letter. However, I am not receiving any realtime device pushes when I trigger them. Nothing shows up as being pushed in my developer account.
One thing that was not available when setting up my developer account was the push enable setting.
Using the /health attribute after my server address shows that the APP appears to connected properly along with my devices automatically populating in the HAC integration.
I receive the following error in my HA log. Aqara bridge is not ready for Aqara Devices; retrying in 30 seconds.
In addition the last update is showing null.
I checked and re-checked all of the keys and IDs being correct and in the proper fields. Started over a couple times. But still run into the issue with my devices not updating in real time
Any assistance would be greatly appreciated.
@rad11
Did you change Message Push subscription mode to All receiving mode (Resource)?
@US-EddieDaYankee. Thanks for the reply. Yes. I ended up figuring that out. I missed seeing the “enable” switch on the page even though your directions mentioned it. Once enabled the Bridge communicated fine with my demo account. I used the 8080/health test to see my devices being triggered in real time. My only issue is that even though the integration found all of my devices and attributes (FP2’s). It doesn’t seem to be communicating in realtime with the bridge. It takes a long time for my devices to update in the integration when triggered. Is there a way to test between the two and narrow down what might be the issue?
Thank you for this write up! How long does it normally take to get through the Aqara 开发者平台 -Iot开发者平台 process? I have been waiting and the console still says
“Your application has been submitted successfully,Please wait patiently for the result of review.”
not sure why it translated the aqara dev page url to chinese.
It’s been like this for me for months. Others here on the forum have also reported that nothing has changed. It doesn’t really bother me since I was previously activated and the API keys still work, but if you are new and try to register, you just can’t access the keys. It’s a really annoying situation. I can’t really tell you if it will help, but maybe you could contact one of the two email addresses listed below the message.
Thanks for the detailed write-up. I have the FP2 integrated via HomeKit directly at the moment but I don’t use HomeKit otherwise
You have to email the global support email address. They get back to you within a day asking what you will be using it for. Then they confirm and establish the account within 24 hrs.
Also. If anyone is out there that can help me. I cannot get the ha integration to update devices in real time. Only occurs when I reload the integration or when things decide to poll. The bridge is functioning properly and receives updates in real time
I have followed the directions above to the letter. Checked and rechecked ids, secret ids, user defined bridge id, etc. deleted and reinstalled the integration and bridge several times.
