I’m making my kitchen smart with an Aqara FP300 and 10 IKEA Kajplats GU10 bulbs. Does anybody have any tips for when it comes to getting the most out of the FP300? Is it better suited in a corner or in the middle of a wall looking down the kitchen? My kitchen is also 6m long and I can install it in the corner near my boiler because I don’t need presence detection near the boiler and this would reduce the length down to 5m. Any tips are appreciated. Thanks
@WorksWithMyHome Great setup you’re planning! For the FP300 in your kitchen, corner mounting is actually a solid choice—especially given your layout.
The FP300 has a 120° FOV and max detection distance of 6 meters, so your 5m effective length fits comfortably within range. Corner installation specifically helps minimize blind spots on both sides during long-range detection, and the eccentric universal joint on the base gives you good tilt adjustment flexibility. Since you don’t need coverage near the boiler anyway, placing it in that corner facing the centerline of your kitchen is pretty optimal.
For height, 1.4–1.8m is the sweet spot for wall or corner mounting to catch both standing and seated positions. If you can hit around 2m with a slight downward tilt, you’ll maximize coverage across the full 5m length.
A couple things to watch: avoid pointing it toward large reflective surfaces (metal appliances, glass backsplashes if possible) and keep it away from your range hood or any fans, as airflow can cause false triggers. The GU10s should pair nicely for responsive lighting automation once you dial in the detection zones.
If you do go corner mount and need to tweak the angle, the base rotates to give you extra tilt range—handy for fine-tuning after install.
What kind of automation logic are you planning with the Kajplats? Separate zones for prep vs. dining areas, or whole-kitchen on/off?
