Aqara G3-Apple Home'da gözükmüyor
My Aqara G3 Hub camera used to appear as a camera on Apple Home. It also appeared on Apple TV. However, after I bought the M3 Hub and moved the Hub, I uninstalled the G3 from Apple Home and reinstalled it. But now it’s not appearing as a camera on Apple Home. Does anyone have any ideas? What should I do? Thanks.
Hello @semaiozcan03
If your camera is added to Aqara Home but not to Apple Homekit, you need to re-add it to Homekit using the HK code on the bottom of the camera. You may have added it as a Matter Bridge (via Matter or the Matter code from the app), as this means there’s no video streaming in Homekit.
Built-in Hub Capabilities : The G410 isn’t just a doorbell; it acts as a Zigbee Hub , a Thread Border Router , and a Matter Controller . This means it can connect to dozens of Aqara and third-party devices, including smart locks, without needing a separate
Hey there and welcome to the forum as @Raman.V mentioned try adding it with the code but first I recomend and reset this way will be erased from apple home app too.after reset add it on Aqara home app then when you add it to apple home app just scan the code from it this way will show as camera streaming on apple home app.
