It should work that way, yes. Or use the Homekit doorbell trigger.
Thanks for everyone’s help. I’m going to try the scrypted project next.
I have found the matter signal a bit hit and miss occationaly, But what I done to combat this, was create a imput boolean switch Called doorbell switch.
then a automation that if matter signal doorbell occupancy changes from clear to occupied then turn boolean switch doorbel switch on, wait 5 seconds then turn input boolean doorbel switch off.
I then use that input boolean switch for all automations related to it.
I found that scrypted was more complicated than I wanted to dig into.
Instead I solved this by getting the $30 Aqara m100 hub, which exposes the G400 as a Matter device with all the needed entities including the doorbell itself.
Update: I’m now using the Aqara Matter Bridging feature, and that appears to work great.
Instructions.
Step 1: Create a Virtual Signal in the Aqara App
Open the Aqara Home App on your phone
Go to your Profile (bottom right corner) > Connect to Ecosystems > Matter
Select Scene and Signal Sync and tap Signal Management
Tap the + (plus icon) in the upper right corner to create a new signal
Under IF , select Add > find your doorbell camera > select Doorbell Ringing
Give it a clear name (such as Doorbell Pressed)
Make sure the “Add to Matter” check box is selected and tap OK
Under Select execution device , choose your M100 Hub and tap Complete
Step 2: Configure the trigger in Home Assistant
Your Aqara Hub will immediately push this virtual signal to Home Assistant via your existing Matter connection
Go to your Home Assistant dashboard. You should see a new Matter entity discovered (typically a binary_sensor or occupancy_sensor named after your virtual signal)
Update your automations to trigger when this new sensor changes state from off to on
Thank you for this, I upgraded frot G4 to the G410 today, because of Home Assitant. Apple Home is still my primary smart home system.
I added the G410 via matter and created the scene sync to get the ring action into home assistant. After that I enabled rtsp in the aqara app and added the doorbell as a camera to the go2rtc. Then I found your integration and changed my go2rtc setup according to the instructions and added the card to my dashboard.
I managed to get it going, by that I mean I get audio and video from the doorbell, but despite my ipad asking for the microphone permission, I don’t hear any audio comming out from the doorbell itself. Is there any more steps involved to get it going?
I love it
My wife was literally asking me earlier this week about it so I shall try that this weekend and let you know how it goes ![]()
