Can I connect 2 aqara hub m2 to each other?I gave a signal problem with some devices
Hello @alexirimia2010 .You can connect 2 or more hubs in Aqara home and they will communicate with each other.
If you have a bad connection, you can connect your device to another hub by adding it again and selecting the desired hub.
Raman.Vās answer is correct and professional. In Aqara Home, you can connect two or more hubs, which will communicate with each other. Child devices can follow the proximity principle to select the most suitable hub for connection.
