The information about the hub appears on several websites.
Aqara Hub M200 – Multi-Protocol Matter, Thread and Zigbee Wi-Fi 6 Home Automation Hub
The Aqara Hub M200 is a next-generation home automation control center designed to unify all your connected devices into a single, seamless and intelligent ecosystem. With native compatibility with Matter, Thread and Zigbee, it ensures seamless interconnection between your devices, regardless of brand.
Dual-band Wi-Fi 6, Matter, Thread and Zigbee compatibility, built-in infrared control, plug-and-play installation, USB-C or PoE power supply.
Smart control center for a complete home ecosystem
Supports up to 128 simultaneously connected devices
Full compatibility with Matter, Thread, Zigbee 3.0 and Bluetooth 5.1
Dual-band 2.4 GHz and 5 GHz Wi-Fi 6 for fast and stable connectivity
MagicPair technology for simplified automatic setup
Built-in infrared control to operate your non-connected devices
Compact and elegant design, ideal for all modern interiors
Compatible with Alexa, Google Home and Apple HomeKit
Technical specifications:
Type: Multi-protocol home automation hub
Supported devices: up to 128
Wireless protocols: Wi-Fi 6 (802.11 a/b/g/n/ac/ax) 2.4 GHz / 5 GHz, Zigbee 3.0, Thread, Bluetooth 5.1, Matter
IR control: built-in infrared transmitter/receiver
Platform compatibility: Alexa, Google Home, Apple HomeKit
Ports: RJ45 (PoE), USB-C (power), USB-A (extension)
Power supply: 5 V 2 A (USB-C) or 48 V 0.25 A (PoE)
Dimensions: diameter 100.5 cm × height 3.075 cm
Operating temperature: -10 °C to 50 °C
Operating humidity: 0–95% RH non-condensing
Certifications: FCC, CE, HomeKit, Matter
Installation: plug-and-play with MagicPair auto-detection
