Aqara Hub M3: Matter multi-admin support (“Joint Fabric”)
Hi all,
I own an Aqara Hub M3 and would like to know whether it supports Matter multi-admin, meaning sharing the hub with a second controller, specifically Google Home (“Joint Fabric”).
What I’ve found so far: the M3 adds to Apple Home via Matter as a bridge, and the Aqara app lists Apple Home among its connected platforms. For Google Home and Alexa, the sources I read describe the legacy (cloud-based) integration methods, without mentioning Matter.
My questions:
•	Can the M3 be shared with Google Home via Matter (multi-admin / Joint Fabric)?
•	If so, should I pair it with Aqara first or go straight to Google?
•	Do Aqara Zigbee devices exposed over Matter remain controllable from both platforms?
Thanks in advance. If anyone has already tested this, I’d be especially interested in your experience.
@ludovic_boue Great questions about Matter multi-admin on the Hub M3! Let me break this down based on what we know.
Yes, the M3 supports sharing with Google Home via Matter. The Hub M3 functions as a Matter Bridge, which means Zigbee child devices connected to it can be exposed to any Matter-compatible ecosystem—including Google Home, not just Apple Home. This is separate from the legacy cloud-to-cloud integration you may have seen mentioned for Alexa and Google Home.
For setup order: You’ll want to pair the M3 with Aqara Home first, then expose it to additional platforms via Matter. In the Aqara Home app, go to Settings → Device page → Expose to Matter to get the Matter QR code, which you can then scan in Google Home during the “Add Matter device” flow. The M3 doesn’t need to be “factory fresh” for Google—once it’s commissioned in Aqara, you share it out.
On multi-admin / Joint Fabric: Once bridged, your Aqara Zigbee devices should remain controllable from both Aqara Home and Google Home simultaneously. That’s the core promise of Matter multi-admin. However, I’d flag that practical behavior can vary by device type and firmware version—some users report occasional sync delays with certain bridged accessories across ecosystems.
Since the Aqara Home app only supports its own Matter controller hubs (like the M3) rather than third-party controllers like Nest Hub as the primary pairing point, starting with Aqara and sharing outward is definitely the right path.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Has anyone here actually run the M3 in a multi-admin setup with Google Home? Would love to hear real-world stability experiences—especially with things like automation triggers firing across both platforms.
I run an M3 and it feeds my Zigbee stuff into Home Assistant over Matter while the Aqara app still controls it too, so it does work with more than one controller. I haven’t tried Google Home specifically, so I can’t tell you how that goes. Pair it in Aqara Home first, then add it to Google. Has anyone here actually done it with Google Home?
Mind multi-admin and Joint Fabric are different things.
Any Matter device supports multi-admin, that is, being able to add it to multiple Matter fabrics, usually one for each smart home platform. If it’s a native Matter device it’s the device the one you add to multiple platforms, if it’s a Zigbee device then the “Matter device” is the bridge (the M3 hub).
Joint fabric is a different, more modern, feature that probably nobody implements yet: instead of having to add a particular device to multiple fabrics at the same time like typical multi-admin, there is one shared fabric and all the controllers (platforms) manage the same fabric.
You probably just wanted to know if it’s possible for a device to be controlled from multiple platforms. The simple answer is yes: if the device is Matter you pair it to the other platforms too, if it’s Zigbee and the hub bridges it to Matter, you add the hub to the other platforms. The devil is in the details, the set of features available in each platform differs.
By the way, the answer will change once Enhanced Multi-Admin (a Matter 1.4 feature) is available across vendors since that will allow to add a Matter device to just one platform and automatically add it to the others without explicitly having to share each device to other platforms.
